solution???
At SMORR, a Samarai Ninja Rock hit one of my hydro lines at the ram on the hydro assist.
Due to many limitations, I was locked into having the lines enter the ram in the rear side. Everyone on the forum says that a 90 degree will limit flow too much.
So, this attempt is the best I could come up with. Instead of using 1/4 90 degrees, I found 3/8 90 degree fittings. I have two of them pointing the entry point now to the front.
Will see how it works at Tuttle.
Oh, did not replace the power steering pump, as it did great on Saturday at SMORR....
AND if anyone ever tells you to check your cooler to make sure that the pressure side is coming into the top of the cooler, and you being that inquisitive guy ask how to do so??? And if that same person says pull the line apart and put your thumbs on both sides and start the vehicle for a few seconds. Well, my advice is not to do this. This method is kinda like watering the lawn with your thumb over the hose. Entire half of my shop is not going to rust with the spray of ATF over everything.
Oh, and I had it plumbed right.
View attachment 950291 View attachment 950292
