I’m hesitant to ask as this might be a stupid question but are both wheels black? The one propped against can looks silver/grey. I ask cuz I’m trying to get some real world photos of wheel color for a metallic grey 2017. Thanks!
295/70R17 Cooper Strongholds, ~2" OME MT64 lift, Rock Warriors with 1.25 Spacers. Removed Factory Mud Flaps, Rival 4x4 Front Bumper. No rubbing anywhere, no other trimming. I've run several sets of 285/70R17s on these wheels on this and the prior 200. The 295/70 looks nicely beefier without the downsides of full 34s or 35s IMO.
295/70R17 Cooper Strongholds, ~2" OME MT64 lift, Rock Warriors with 1.25 Spacers. Removed Factory Mud Flaps, Rival 4x4 Front Bumper. No rubbing anywhere, no other trimming. I've run several sets of 285/70R17s on these wheels on this and the prior 200. The 295/70 looks nicely beefier without the downsides of full 34s or 35s IMO. View attachment 4073132View attachment 4073133View attachment 4073135
E rated. Only downside of the 295/70 is I think you can only get E rated tires. I've never had an issue with E Rated Tires on a 200, but we load pretty heavily and do beat on them a bit.
E rated. Only downside of the 295/70 is I think you can only get E rated tires. I've never had an issue with E Rated Tires on a 200, but I am sure that SL rated Michelins are smoother.
I also just moved from that size ^^^. Was running E-rated Toyo Open Country AT3 in 275/70/18 and while they performed well for me over 45k miles they had become horrendously bad on wet pavement (like dangerously bad). Switched to Falken Wildpeak Atw4 285/70/18 C-rated and they handle bump pavement and washboard so much better than the Toyos. The vehicle handles much better. Have not had them in a real off road enironment yet so I cannot comment on that. I love the tire so far although they are heavy and wobble a bit at ~55mph before they warm up. I think I will take them back to have them re-check the balance. I am running 1.25 spidertrax with an OEM coil spacer and aggressively cut the fender liner as well as pulled it forward as these tires tend to run a bit large for the size.
SCS F5 18" +25
Nitto Ridge Grappler G3 275/70/18 (117T)
Stock height Bilstein 4600's, planning to install Toyota spacers and paint the center hubs black soon
Thought I'd mention that with the BMC, 1.5" BL, 2.5" suspension lift, and the KDSS max relocation lift... I still touch the sway bar AND the BMC plates with 37s... But it's worth it.
Thought I'd mention that with the BMC, 1.5" BL, 2.5" suspension lift, and the KDSS max relocation lift... I still touch the sway bar AND the BMC plates with 37s... But it's worth it. View attachment 4080851
My guess is that would solve it. I'm actually petitioning Milestar to make a 38x11.50R17 Patagonia. Nitto is really expensive. I did just discover that Toyo has one or two options in this size. I won't make any changes to tires until after I install the portals this spring.
My Black Rhino Dugger wheels have an offset of +10. I am super bummed because I own 7 to match my trailer and I have to sell them now. I spent many months searching for a wheel like this that includes a removable "rock guard ring". My new wheels will be a +50 offset and a different lug pattern.
I would (try hard to) be happy with 37s if not for the portal axles. I have decided to partner with Portal Pros who have a 25% gear reduction at the hubs. Because of this, I feel that 38s might be better. Also with the automatic 4" lift, I should have more clearance. Trying to reduce my suspension lift now with the help of @cruiseroutfit.
Higher offset additionally helps with the extra width of the portals. Not to mention I am forced to go 6 on 5.5 bolt pattern.
Kenda Klever RT 35x10.5x17 on Nomad 504 wheels with Billsteins on the 5th perch up front (picture of what we had to cut) and Dobinson 2" springs with Bilsteins in the rear. Only slight scrub on the KDSS at full lock to the right... very pleased.
My .02… Look into Kenda tires, I’ve had two sets on two different vehicles. I have 5 people get them and love them, I used to work at an off road shop, so I have had a lot of reviews from owners / shop techs/ person seat time, and everyone who tries them loves them. I have not seen a tire mount and balanced with over 2 oz of weights! https://automotive.kendatire.com/media/737751/pcr-spec-sheets-2025-klever-at2.pdf
So in all of your experiences, no issues with balancing the tires? I'm dealing with a subtle vibration above 60mph that I am hoping goes away after getting rebalanced...
