Alright.. narrowed my next tire size to 34s, specifically 285/75/17s. But going back and forth between these two tire choices and could use some recommendations:
Falken AT4W C load
BFG KO3 E load
Use case: The truck is mostly stock, unloaded, sees occasional offroading (nothing extreme, no moab). Coming from 285/65/18 KO2 E load that are nearly new, but I could use a bit of more comfort due to having a bad back.
Wondering if going with KO3s and increase in size will provide comfort improvement from a taller sidewall (+ lower recommended tire pressure) OR is the only way to get more comfort is to go AT4Ws in C load while compromising little in tire strength.
The other two concerning factors are reviews of Falkens poor stopping distance in snow and additional 5 lbs per tire compared to KO3s (68 vs 63 lbs), but also seem to have thicker/taller tread.
I have also narrowed my shopping to those two off-road all-terrain tires and in that same size or perhaps 295/70R17. However, my decision leaves snow traction out of the equation because I run dedicated winter tires (Blizzak DM-V2). Wet weather is high on my priority list. Similarly, my truck is mostly stock except thick steel skid plates and all=terrain tires. Rock sliders are certainly in the future. I plan to keep AHC. Fitting the 34" tires will require a bit more massaging of the front wheel well plastics. I don't see going to 35" without beefing up the drivetrain to reduce the risk of breaking a CV joint or something. I look forward to more mid-level off roading to add to my Imogene Pass, Grand Canyon north rim, etc. adventures. More southern Utah and Moab, Colorado (Black Bear Pass), etc. roadtrips are in my future.
For me, it seems to come down to these factors:
1) additional unsprung weight of the tire negatively affecting on-road ride & handling.
2) likely stiffer sidewall and ride of the E-load rated KO3.
3) KO3: has BFG resolved the sketchy wet weather traction that affects the KO2?
Considering my rig is the family truckster and my wife's daily driver, the likely better on-road ride quality of the C-load Falkens would likely push me that way. Both tires look good with their aggressive tread and sidewalls. I assume road noise is comparable between the two - would like more consumer confirmation. Furthermore, the many stories of the KO2 questionable wet weather traction leave me wondering if the KO3 addressed them.
On the other hand, if I could really have my cake and eat it too, I would have three sets of tires, but convincing my wife would challenging:
255/70R18 Bridgestone Blizzak take care of winter.
275/60R20 or 275/65R20 Michelin Defender LTX MS2 on original 20" wheels for on-road other three seasons.
285/75R17 or 295/70R17 all terrain on Rock Warriors for the off roading. If I could have three sets of tires, I think BFG KM3 would be fill the off-road tire category.
That I've managed to acquire four sets of wheels is bonkers. However, only paying $125 for the Tundra wheels, $350 for the Land Cruiser wheels, and $400 for the Rock Warriors certainly softens the blow.
Phew... that's a lot. Happy shopping.
