Head up i84 East and you’re three hours from hot springs mountains and high desert
Looks like Bridgeport perhaps?
You got it, that was a couple weekends back. This last weekend was Hidden Falls Adventure Park below for a couple of nights of camping and wheeling. I wish this place was as close as Bridgeport because it was pretty great.Looks like Bridgeport perhaps?
Thought we'd do a little exploring today and see some local lakes that we previously hadn't been to. Made it about 100ft into a snow-covered trail before I high-sided like a total idiot.
Rocking didn't help. Centre diff lock didn't help. Crawl control didn't make a difference. Four guys pushing (after digging the wheel out w/ shovels) didn't help. Didn't have my MaxTrax with me, but suspect they would have been useful.
This wouldn't have been as much of an issue if I didn't have a broken leg and wasn't moving around on crutches. Thankfully I picked a good spot to be dumb: right in front of a group of 6-8 trucks and a bunch of people. I also had most of my recovery gear (strap, shackles, etc.). The guys dug out what they could, and a 3rd gen Tacoma yoinked me out after 7-8 attempts. The LX is a heavy beast!
Now I'm thinking about winches again...
If you like to go wheeling in the snow a winch is a must. I use mine constantly, it has been a lifesaver. I’m also surprised how often I use it to clear the trail as well. Check out the link below.Did the LX get into the extra high mode when it sensed it was stuck?
No, I put it into high (and 4L) in an attempt to un-high-centre myself.
If the LX is in AHC high and senses it is stuck. It’s supposed to raise another 1-2” or so.
Did you adjust AHC at all at the time?
Whaaaaat?! I've never heard of that before, but that's pretty wicked.
I did hit the "up" on the AHC height control at some point, but can't recall whether that was before or after I put it into 4L.
| Front (lift) | Rear (lift) | |
| Stock AHC "N" | 34.5" (1") | 36.125" (1") |
| Stock AHC "H" | 36.5" (3") | 38.5" (3.375") |
| Sensor Lifted AHC "H" | 37.25" (3.75") | 39" (3.875") |
| Sensor Lifted AHC "Extra High" (projected) | 38.0" (4.5") | 39.75" (4.625") |
Ayup to @04UZJ100
The system will deploy extra-high mode when it senses the vehicle is stuck and/or stuck in crawl control. It'll conjure up another ~1" front and rear. Could be helpful to get the vehicle out when it's stuck on its frame rails.
With my mild setup of 33" tires, .75" sensor lift, and AHC, that's a solid 4.5"+ lift when I may need it most. Measurements from ground to fender (suspension and tire lift, w/ 305/55/20 33.2" tires):
Front (lift) Rear (lift) Stock AHC "N" 34.5" (1") 36.125" (1") Stock AHC "H" 36.5" (3") 38.5" (3.375") Sensor Lifted AHC "H" 37.25" (3.75") 39" (3.875") Sensor Lifted AHC "Extra High" (projected) 38.0" (4.5") 39.75" (4.625")
I’m curious did you have one or both rear wheels spinning?![]()
Thought we'd do a little exploring today and see some local lakes that we previously hadn't been to. Made it about 100ft into a snow-covered trail before I high-centred like a total idiot.
What was your tire pressure?
Oh man, you were dead before you even started with that tire pressure. You can have the biggest tires, the biggest lift, etc., but if you don't air down your truck in worthless in the snow. Time for a compressorStreet pressure of 33-34 PSI. Airing down was a last-resort option, as I would have had to get my fiancee to do it, and to then inflate the tires back up.
