- Joined
- Apr 9, 2013
- Threads
- 236
- Messages
- 2,151
I just bought a Fumoto and it says on the packaging to go hand tight, then add 1/8 of a turn with a wrench. That seems pretty non-specific to me, but that's what they tell us to do.
I followed this to a "T" and have not had any leaks. I worried about snapping the hollow plug by over torquing, so decided to be a bit less enthusiastic.I just bought a Fumoto and it says on the packaging to go hand tight, then add 1/8 of a turn with a wrench. That seems pretty non-specific to me, but that's what they tell us to do.
This makes sense as the ‘bad’ reviews of these are from breaking and I’d guess they torqued to OEM spec rather than following the direction.FSM bolt torque assumes it’s a tech with a torque wrench. Fumoto likely doesn’t want to assume that, not to mention many people may not have the adapters or know-how to torque anything other than a regular bolt/nut.
Plus with the hollow construction we can’t assume the FSM spec won’t break it.
I agree what they say to do seems reasonable.
Good thing I asked before I installed mineThis makes sense as the ‘bad’ reviews of these are from breaking and I’d guess they torqued to OEM spec rather than following the direction.
I’ve also been curious bc I am going to do the same thing.Good thing I asked before I installed mine
Hi @bloc
See the more recent pages of this threadHi @bloc
Where did you find this manual?
Wondering if I could source one for a 2021 land cruiser - I am spoiled by a big physical manual for my 60 series.
Thanks,
Fraser
forum.ih8mud.com
Actually...See attached PDF file for engine model 3UR-FE. 3UR-FE is the V6 engine model (not the diesel that is more common in Australia). Pay attention to Nm versus ft lbs for torque values.
BTW one inconsistency between the official Toyota shop manual attached as PDF in my previous post and the owner's manual is the viscosity of the oil. See screenshots. How would one explain that inconsistency? Thank you.
The shop manual applies to model code URJ 20#, which is J200 with the V8 petrol engine sold in the U.S. All oils referenced exist in all major markets. The owner's manual is the one sold in the U.S. market. Irrespective of this, the 3UR-FE engine does not know in which market its operating. 0W-20 is not mentioned in the shop manual. Why not?First .. check the level when you refill. Go low.. like 7.5 and add till you know "your truck".
USA vs non-usa and where you live. oil is a temperature and availability thing.
LC200 is world wide.
