GTV
Hi, for the rock warrior wheel runnners are you guys running The spacers On just the front or front and back
At a minimum you need a 10mm or 3/8" spacer up front.
Looks great, what is the lift? Thx
Stock t-bars cranked to 20.5” center hub to bottom of fender, diff drop.Looks great, what is the lift? Thx
Picked up some Tundra take-offs after cracking one of my 200 series rims on a storm drain.
Happen to have a pic of the cracked rim? I’ve never seen or heard of someone cracking their factory LC wheels?
Maybe cracked is the incorrect word. Kind of hard to get a good pic but basically the spiraling on the clear coat around the hit is also deformation of the metal. Like a surfboard pressure ding. Seemed like something Al is not supposed to do. Thoughts?
Maybe this shows my concern a little more. I’m not gonna lie, I had my eye on the tundra off roads for a bit anyways so maybe I’m just making excuses in my head.Did the storm drain make direct contact with the wheel? From the picture, those look like scratches more than stress/pressure cracks.
btw, I'm in a gray 06 with no roof rack or running boards, wave if you see me around.
Sorry for pulling up old post but could you please let us know what tire size you’re running here? Just looks amazing. Tundra steelies?
Its in my signature and yes tundra steelies. Super heavy wheels so i sold them.Sorry for pulling up old post but could you please let us know what tire size you’re running here? Just looks amazing. Tundra steelies?
Yep. Mounted to 275 65 18 KO2s with 1.25" spacers all around.Is anyone running these?View attachment 2601619
It seems a lot of guys run 1.25" spacers. Is the larger spacer so they can clear the grease cap on the front axle without having to modify it? I'm curious because I just bought a set of RWs from a 200 owner and he had 1" Bora spacers included with the deal. They obviously won't work on the front, but after installing them on the rear I like the lack of "poke" and would like to run 1" spacers on the front as well. I'm assuming I'll have to modify the grease caps slightly, but wondering if there is anything else I'm missing here. Worst case scenario I'll just get 1.25" for the front, and keep the 1" in the rear but I'd like to avoid that if possible.At a minimum you need a 10mm or 3/8" spacer up front.
Awesome. Thanks for the info, GTV! Looks like I'll put my order in for the 1" Boras and look at these beautiful wheels sitting in my garage every day for the next 2-5 weeks...1.25” is the common “mass” produced size. It is this width to ensure there aren’t any issues with the factory studs protruding past the spacer and interfering with the wheel (on a variety of applications). You will have rubbing issues up front with 1.25” spacers and 285/70’s, thinner is better if you prefer not to modify anything else.
A good machine shop could take off 1/4” I would think. But may be more expensive than buying new 1”.Awesome. Thanks for the info, GTV! Looks like I'll put my order in for the 1" Boras and look at these beautiful wheels sitting in my garage every day for the next 2-5 weeks...![]()
They do - I think my message was a little convoluted and got misinterpreted. I have 1" spacers for the back already and have already verified they work (pic above), and I planned on ordering 1" spacers for the front. Just wanted to make sure I wasn't going to run into any issues running 1" spacers in the front as I noticed most run 1.25" but sounds like I should be good to go. Thanks for the replies, fellas.I think BORA makes them to order.... so if you want 1", place an order. I just inquired last week, and lead times were 3-4 weeks for the spacers
