1st photo on the cart: 1FZ - Toyota Bellhousing - H15X - NWF black box - hf1a that we swapped to a an HF2A so we could put 3:1's in. Can't do that on a HF1A@Cruisers and Co pardon my layman's lack of knowledge, but what the hell am I looking at here? That's an H55 bolted to a 1FZ bell housing? Did you cut off the transmission side and weld on a new plate machined for the H55? Definitely sexy, obviously being built for someone who wants to tangle with some boulders!
I'm now committed to @wngrog H150 and HF1A, but how does this change the math on parts I'm already tripping over? I have the 275mm fly wheel, but there is a 300mm option available, is that a meaningful difference for this sort of project? What about the clutch itself, it's not listed for the 1FZ but it is the same 275mm? For easy reference, here are the parts I have already.
Flywheel (FZJ70) : 13405-66020 275mm
Clutch Disc : 31250-36343
Clutch Cover (PP) : 31210-36330
Slave Cylinder : 31470-60171
Pilot bearing : 90363-15017
Release Fork : 31204-36110 (this is for a 1PZ, but is what FJ Co. used???)
T/O Bearing : 31230-60130
Flywheel Bolt: 90913-01021
Bell Housing: 31111-60302
Thanks!
Clark
2nd Photo: 1FZ - FJco - Bellhousing - H55F - NWF Black Box - Splitcase with 3:1's and yeah @gonzopancho likes to party
We’ve used uniclutch’s in our setups with great success. The 1FZ-h55 is running a 275mm flywheel with a uniclutch 4terrain unit. We’ve done another 275 mm flywheel h150 unit with the Uniclutch sport and that was great, liked that unit a lot. Forget the numbers from that truck but it was up there in power, +400whp and over 500 ftlbs. The other h152 black box combo I posted above is running a uniclutch sport also on the 275. It’s on the road as of this week and while not boosting to the moon yet… it’s doing great.So I understand I need a new clutch kit to go with the H150, but can I retain the 275mm flywheel rather than having to buy a 300mm? Or would I potentially regret that smaller size of I were to add a mild turbo someday? Are the 300mm clutch kits more readily available than the 275mm?
Thanks!
