1FZ-FE scaled injector setup
Can i be added to your list?
AFM to MAF conversion?
so I have 2 kits available right now and I'm looking for a couple of people interested in installing them. I'd me most interested in people who can provide some performance data that I might not already have. Being in New England i've done plenty of cold weather testing and have done several long distance runs. I'd like so see some hot wearher and mountain runs to to round out the testing.
let me know if you are interested.
thanks
I run a obd1 setup and the guy that put it together put the wrx blues with spacers and could never get it working right. Eventually it was all dialed back to 3.5psi, stock injectors re-installed and I drive it gently/only occasionally while keeping an eye on the AFR. At WOT, its not in the range it needs to be. My assumption was that I was going to have to piggyback an ECU with bigger custom injectors, bigger fuel pump and a MAP sensor setup. Hope you have success with your project, wish I could help be part of it.
Yes the kits are being assembled and will be sole through Absolute-wits-end.com. Look for an announcement from him.
Outstanding!! Wits end is an awesome supplier. Any idea on timeline? I currently have an OBD-1, and a 7th injector kit would be an engine savior with the TRD SC. Thanks!
doesn't work with OBD-I systems as they don't use a MAF sensor, sorry
Roger that/copy all. I know there is another post where they talk about a 7th injector to cure the lean issue on the OBD-1 systems, but I’m looking to buy a kit for that, meaning extra fuel injector spacer, line, split second enriched and injector controller, etc...any word on something like this being produced anytime soon or already in the market for the unlucky OBD-1 bubbas wanting an SC or Turbo? Thank you, sir.
Looking for the larger SC CNC MAF housing to replace my 2nd gen Landtank MAF housing.
Wits end is apparently out of stock on the kit but looks like they don't sell the MAF housing separately.
Do you have any in the production line?
kits are available and have been for a while. Shoot me a PM and I'll take care of it for you.
