1FZ build continues....
The woods
Well, it’s going slow, but my mechanic buddy has been working his magic on my 1FZ. What’s been done so far:
1. Block completely disassembled and cleaned, all oil passageways cleaned. The cylinders were, according to his bore micrometer, less than .0001 out from top to bottom-well within spec. Honing was the only “machine” work necessary.
2. Here are some pics of the strip and paint process
Before:
1907121
Stripped:
1907122
Epoxy primered:
1907125
Painted, with Standard LCE rebuild pistons installed:
1907126
Since then, I got him a new timing chain cover/oil pump, water pump, 3fe fan clutch, and many other new goodies.
Here are some progress pics as of Thursday, with the oil pan installed:
1907129
Looks nice, it is good to have a mechanic as a friend. Think he would do mine?
I’m sure he would. He is a Honda guy from way on back, but he is very impressed with this motor, and seems to be enjoying the opportunity to work on something that isn’t “normal”. Also, I wouldn’t trust anyone else to go to this level of expense and time consumption on a project like this.
I’m a builder, so I built his personal shop several years back. It’s a good arrangement.
Wow, excellent work.
Wish that guy was close to me. About time to pluck my engine and freshen it up.
Sweet Work , What Part of the woods you guys in ?
Very nice but I’m always curious what it was that prompted a full overhaul?
I always wonder about that too. In my case...my engine has developed so many leaks it will be easier for me to pull it to address all of them. If I do that I might as well clean up the oil cooler and replace the parts therein, have the head serviced. I have my original head gasket (we all know about that) (305K miles).
I expect to find my lower end in pretty good shape. Hoping to just hone the cylinders, re-ring the pistons, replace all bearings. Check the condition of my oil pump, timing chain and tensioner/slipper. Button it back up all clean and sealed and go another 300K (if I live that long).
I could probably drive it as is...another 200K who knows...but the old gal deserves a freshening up.
I agree that if one has to pull the engine, and that engine is as you describe yours to be, and one has the funds to do a proper rebuild, one might as well.
I always wonder what “major” issue, if any, there was to prompt a rebuild or if it’s just that persistent paradigm which tells us all engines need a refresh once past 100k or 200k or quarter million miles; contempt prior to investigation.
I wonder the same thing. It would be interesting to get feedback from folks who have rebuilt their high mileage but otherwise fully functional engines. Is it - wow this feels like a new car again with a big bump in power, mpg, etc...., or more like, umm it till runs and feels about the same as before.
I'm right about 312k on mine and its not giving me any clues that a rebuild is in the near future. If I was retired, had some extra cash and time, etc... then sure, more for the enjoyment than the necessity.
In a funny way I sometimes feel like the non rebuilt engine is more of a "known quantity" in the sense that I'm confident it was put together correctly since it has proven itself over so many miles and years.
In either case it looks like the OP is doing a great job! Post the startup video once its done.
^^^^ There is no question mine will end up being just about the same. I don't know the condition of my injectors...but my engine runs smoothly now. When I checked my compression last year I had 190 psi on all but one cylinder it was just slightly less. I'm sure my lower end will look good, but I've got to get these leaks fixed and do the head gasket as prevention.
I'm at 305K now.
Ahhh, questions.....cracks thumb knuckles
I sold a very reliable, very low mileage Tacoma 4x4 extra cab that had been my adventure truck for a while. I put about 50,000 miles on it, and had some good times driving to backpacking trailheads and camping/short-trip overlanding with my wife.
1907688
Since that time, our son has gotten old enough to come along with us, and I wanted a tough expedition vehicle that would hold our family without requiring a serious movement of gear or humanity just to shuffle the boy in and out of the vehicle.
Well, the Tacoma has actually appreciated in value, so I sold it and bought this (only exterior pics I have were from the Craigslist ad):
1907689
Here begins the actual answer to your question. When I looked it over, it had lots of oil leaks, so the immediate plan was to pull the motor and have my buddy do a full clean/seal job. If there’s anything I can’t abide, it’s an oil leak. It ran very well on the two hour drive home, and I didn’t get the sense that anything was wrong. Power was good, and it ran reasonably smoothly.
However, my friend ran a compression test, and found that one cylinder was only making 90-something PSI. Also, the plugs were completely black....it was burning oil in a big way. As I suspected (due to the new radiator), someone had overheated this LC. The oil pressure was also a bit thready...it never really got low, but it fluctuated up and down with engine speed pretty badly.
At that point, since the money was available, I made the decision to do a total rebuild. E is a great guy, and we’ve helped each other out many times in the past. Also, I had seen a reseal he did on a Toyota Cressida, and the motor came out looking like new, so he was always going to be the guy.
If you’ve got the motor out, and if you have a buddy who is very picky and particular about the way things are done, and if you are, yourself, very picky and particular, you go with the full-blown rebuild!
Anyway, I'm proud of it.
I sold a very reliable, very low mileage Tacoma 4x4 extra cab that had been my adventure truck for a while. I put about 50,000 miles on it, and had some good times driving to backpacking trailheads and camping/short-trip overlanding with my wife. View attachment 1907688
That's a very nice rooftop tent. ;)
Better than on the Tacoma.
Sold that one when we moved. We’re in the process of building our house, and I didn’t have anywhere to store the thing, so it had to go.
I’m thinking of going with an Oztent for the new setup. The only problem with a rooftop tent on your vehicle is that once you pop it, you’re stuck for the rest of the night. Love it for comfort and quick setup, though!
I rebuilt mine after pulling it to do the HG and found the top of the block pitted. Decided the best course was not to half ____ it and just rebuilt it. After done there was SIGNIFICANTLY more power available. Very noticeable change in acceleration, could even get out its own way. Getting on the freeway was no longer like playing dodge ball. Still no sports car by any means but a significant improvement for me. Also picked up about one MPG on fuel use. I had my bottom end rebuilt at a shop, along with the head, so I have no idea of how the bearings or crank looked but the re-builder was impressed with the engine for the mileage (just over 200k). It did have significant carbon build-up on the valves and piston tops.
