SOLD 1997 SUPERCHARGED 80 series
Status
Not open for further replies.
Atascadero, CA
Year
1997
  1. 80 Series
Mileage
231087
Color
White
Outside Link
https://www.facebook.com/marketplace/item/1355299488664594
SUPERCHARGED 80 Series Landcruiser. 4x4 Labs bumper, Slee Sliders, Slee 4" Lift, Custom Built Cargo Rack, Warn Winch with Wireless Remote, Lockers function, Flowmaster Catback Exhaust, Cold A/C, Trailer brake controller with 7 pin connector. Supercharger has been on since 140K Miles
Recent Maintenance:
- Full front end rebuild
- Brake booster replaced
- Upper oil pan reseal
- OEM Oil pump seal
- OEM Front main seal
- OEM Rear Main seal
- OEM Valve Cover Gasket
- OEM DIstributer O ring
- Denso Spark Plugs
- OEM Wires
- OEM Distributor Cap
- Land tank Orange Fan Clutch
- OEM Radiator
- Transfer case fluid
- Rear Diff fluid
- Trans Fluid
- Toyota Red Coolant
- GM Supercharger oil
- Denso 02 sensors
- Handbrake Adjustment
- Re-manned Denso 2.0kw starter
- OEM Engine Mounts
- OEM Transmission Mount
Interior
- Mosley leather seats front and middle
- New OEM foam for front seat bottoms
- Seats front and back are set up for heat, but not currently connected
- Rosen Sun Visors
- Alpine single din head unit with bluetooth
- Focal Speakers
- Scan Gauge II installed
- LED dome lights
- Center diff lock switch
- Dashboard is pristine
Exterior
- Slee short bus front bumper
- Slee 4" Lift
- 4x4 Labs dual swing out rear bumper
- Warn 9.5xp winch
- BFG 315/75/r16 all terrains
- Rust free other than minor surface rust on undercarriage
Things worth noting:
- CA registration good thru Jan 24'
- High lift jack included
- Perfect match Steering wheel skin included but not installed
- Have hood risers from Solve Function
- Needs a new gasket on
Pricing break down:
40,000 Perfect condition 80 with these miles and mods.
- Subtract 3,000 Head Gasket (preventative)
- Subtract 1,000 Supercharger Rebuild (preventative)
- Subtract 1,000 for any small cosmetic issues and anything else haggle worthy
That brings us to 35k. If you're interested please reach out. I am willing to negotiate if going to a good home. Thanks!
Recent Maintenance:
- OEM Oil pump seal
- Denso Spark Plugs
- OEM Wires
- OEM Radiator
- Rear Diff fluid
- Trans Fluid
- Denso 02 sensors
- OEM Engine Mounts
Interior
- Rosen Sun Visors
- Focal Speakers
- LED dome lights
Exterior
- Slee 4" Lift
- Warn 9.5xp winch
Pricing break down:
Very nicely presented with lots of relevant info. Looks like a great build in fairly good condition. Well worth every penny you're asking.
woah, sersiously nice! do you happen to have a walk around video, interested. the exhaust has to sound pretty great too I'd imagine!
when you do a slee 4" lift was any driveshaft work required? any vibrations? was this a factory slick top? or did you remove the port installed rack?
really nice 80!
really nice 80!
I dont believe there was any driveshaft work. Slee did the lift and I was not the owner when they installed it. No vibrations. And the rack was on there when I purchased, it is a factory slick top.
I am working on uploading the videos of the exhaust and a walk around. Trying to figure out the format that the site will allow. It doesn't like mp4 apparently
I uploaded to youtube so you can view there. Thanks.
thanks for the video! really does sound nice, lots more low end grumble compared to the stock setup.
what a truck!
Status
