SOLD 1997 Lexus LX450 "FZilla"
Status
Not open for further replies.
Eugene, Oregon
SOLD!!!!
For Sale: A 1997 LX450 that is built from bone stock 2 years ago into a off road beast. When I do something I go all the way. I tried to mirror jcardona1's FJ80 as much as I could as I truly think that is one of the best out there. This FZJ80 followed suit with 4 Wheel Undergrounds 3Link in front (Stage 3) with matching rear shocks from Radflo, rear OME springs. For protection, went to Luke at 4x4 Labs and went with there front and rear bumpers along with sliders. Gears were upgraded to 5.29 and all wheel and axel barrings were replaced with Koyo or Timkin. Additional, Nitro Gear chromo axles & berfs were installed.
This list is extensive as to what I have done. Basiclly if I touched it, it was replaced with premium gear.
Additionally, I went trick on the audio system with a nice Alpine INE-W967HD paied with KAC-001 so the ARM compressor and lockers are controlled by the screen on the deck, not switches on the dash. JL Audio ZR separates, Polk Audio coax rears, JL HD amps to power front and rears along with the JLW6v3 10" sub in custom box.
It has 194k miles.
I just can explain how much effort, time, and money went into this build so I will list what I have receipts for and show you in pictures. As I find the words to write all I have done I will expand but I am a motivated seller due to financial issues.
Asking $15,000 OBO. Motivated to sell, reasonable offers will be heard. No trades.
Any questions, please don't hesitate to ask.
My build thread can be seen here.
The Rebirth: FJZilla 2.0
Item Price
4X4Labs Front Bumper $1,150.00
4X4Labs Rear Bumper Double Swing w/Tire Holder $1,725.00
4X4Labs Sliders $995.00
AFE Prodry Air Filter $56.95
Aisin Free Wheel Hub $290.00
Aisin Hub 300M upgrade gear $110.00
Alpine INE-W967HD $1,500.00
Alpine KAC-001 $150.00
ARB CKMTA12 Twin Air Compressor $491.63
ARB Manifold Kit $64.13
ARB RD132 front locker $910.50
ARB RD142 rear locker $910.50
ARP Steering Arm Knuckle Studs $178.00
ATX WHEELS AX757 CHAMBER PRO II BEADLOCK BLACK TEFLON $2,305.00
Axle Rebuild Kit $175.00
Barnes 4WD Frame Shock Tower $135.00
Cruiser Crap $99.00
Cruiser Gear Paracord Handles $80.00
Denso O2 Sensor $48.78
Extended Front Drive Line w/ New Flange & U-joints $272.44
Four Wheel Underground 3 Link Kit w/ Rear Shocks Stage 3 $4,531.00
Front & Rear Window Belt Moulding $156.48
Front Pinion Solid Spacer $32.00
G&J Aircraft Front Extended Stainless Steel Brake Lines $63.00
Heater Valve $36.99
iPad Pro iPad Pro $111.98
JL Audio 10W6V3 $400.00
JL Audio HD600/4 $675.00
JL Audio HD750/1 $675.00
JL Audio ZR650-CSi Separates $699.90
Knuckle Rebuild Kit w/ koyo wheel bearings $194.75
Les Schwab 27F Xtreme Power Battery $131.78
Lokka Part Time 4WD Kit $299.00
Manafre Rear Stainless Steal Brake Lines $97.50
Manafre Sway Bar Drop Brackets $52.50
Metal Tech 4X4 Offset Rear Lower Links $325.00
Metal Tech 4x4 Rear Upper Links $250.00
Metal Tech Rear Sway Bar Drop Bracket $34.95
Nitro Gear Chromoly Birf Kit $736.75
OME 2423 Rear Coil $223.50
OME Rear Panhard $238.93
Panavise Ram Mount Holder $32.95
Polk Audio MM651 Rear Coax $137.77
Rear Lower Shock Mounts $49.99
Rear Pinion Solid Spacer $55.00
RHD Toyota Steering Arm $129.99
Ring & pinion kit front $146.06
Ring & pinion kit rear $123.26
Ring & pinion sierra front $215.65
Ring & pinion sierra rear $221.83
Rough Stuff Steering Stops $7.00
Rough Stuff Toyota Knuckle Gusset $19.50
Slee High Steer Arms $550.00
StopTech Brake Rotors & Raybestos Calipers $831.86
Toyo 37/13.50 Open Country M/T $2,189.20
Toyota OEM Air Cleaner Hose $86.00
Toyota OEM FJ80 Snorkle $299.99
Toyota Radiator Cap $11.15
Toyota Remanufactured Starter $189.19
Toyota Thermostat $16.93
Toyota Thermostat Gasket $3.65
Toyota Transfer Case Bearing $31.74
Toyota Transfer Case Oil Seal $15.58
Trail Gear Trail Safe Knuckle Ball Wiper Seals $61.95
Versionex Bodyshop Cut & Modify Front & Rear Fenders $3,200.00
Versionex Bodyshop Raptor Black Urethane Spray On Bed Liner $400.00
Versionex Bodyshop Snorkle Install $150.00
Viper LCD 2-Way Security + Remote Start System $700.00
Whiteline BTR46X Rear Sway Bar $251.82
Wits' End Modified Toyota Blue Fan Clutch $249.00
Wits' End Seat Extension Bracket Kit $142.00
Total in parts and body work that i have receipts for- $32,132.00
full
full
full
full
full
full
full
full
full
full
full
full
full
full
full
full
full
full
I'm relatively new to the site, so I started a conversation...
Oh well, that stinks. Great buy!
Well i thought i was the lucky winner here!!! I had a make shift contract w the mans banking info to wire money first thing in morning than i received a text just before midnight my time w the seller asking for more money. Good luck to the man that out bided me. Guess the ad here should have had a reserve of 15k w a 5 day auction.....:bang:
Nice job on that contract/agreement you emailed me last night TOO BAD YOUR NOT A MAN OF WORD. Yes I'm a little MIFFED
You should probably meantion the rear main seal leak in your ad. Which by the way didn't deter me from the sale. Buyers be warned.
Regardless of what transpired, this rig was WAY underpriced! I know what I would have paid for it all day long...
Status
