SOLD 1990 Land Cruiser HZJ73 ZX - California title - SF Bay Area
CA
**** SOLD ****
Selling my 1990 Toyota Land Cruiser (HZJ73). Clean and clear California title in hand. If you are familiar with these trucks you know how difficult it is to get them registered in California. This truck is smog exempt, so it will never need a smog check.
The truck has 199,905km (123, 712 miles) on it when I received it at my house. It now has 205,594km (127,750 miles) on it. I purchased this Land Cruiser in March 2015 from Steve Jackson at LandCruisersDirect.com. The truck was legally imported from Japan and is a Right-Hand Drive truck. It has a 4.2L 1HZ Diesel engine to which I fitted a Safari Turbo kit. It has an A440F automatic transmission. The truck has electric windows and door locks. It has air conditioning as well. This is a 27-year-old vehicle, so it’s not perfect, but it is very clean for its age. There is a small rust spot forming under the passenger’s door. It is about the size of a silver dollar. This truck has been my project for the last 18 months. I have spent hundreds of hours refreshing the sub system under the hood and the entire drivetrain. I have invested $16k+ in parts alone(not including labor) into this truck. I would not hesitate to drive it from San Francisco to New York and back and not worry about anything. This truck is solid and runs great.
Along the way, I have added a number of upgrades, such as the Safari Turbo kit, Wholesale automatics valve body, ISSPro gauges, Old Man Emu lift kit, new tires and wheels, Pioneer AVIC head unit with handsfree calling and backup camera, 4 Pioneer speakers, Pioneer amp, BMW seats, front and rear 4x4 labs bumpers, custom rock sliders and the list goes on….
I only used Factory Toyota Parts where available. Most of the work was performed within the last 12 months. I have driven this truck less than 5k miles and it has been flawless. I love this truck, but I found a new project and this one needs to go to make room for the new project.
I have an excel spreadsheet with all the parts, date of install, mileage and cost. I have all the receipts for the build as well. Asking price is $30k. PM me directly if interested.
Below is the parts list for this Land Cruiser:
Safari Turbo Kit
Boost Compensator Kit
3" exhaust system
Aeroturbine muffler
Wholesale Automatics A440F Extreme Stage 2 Heavy Duty Valve Body
ISSPRO EV2 SERIES BOOST GAUGE
ISSPRO EV2 SERIES PYROMETER GAUGE
ISSPRO EV2 SERIES TRANSMISSION TEMPERATURE GAUGE
ISSPRO CLIPSENSE SENDER MOUNT
ISSPRO EV2 GAUGE LIGHTING WIRING HARNESS
ISSPRO EV2/PERFORMAX MOUNTING BRACKET
ISSPRO ATTRIBUTE PROGRAMMING SOFTWARE KIT
Pioneer AVIC-6200 Head unit
Pioneer Amp
Pioneer 5" speakers
Pioneer 6x9 speakers
Pioneer backup camera
REDARC BCDC1220 Dual Battery Charger
Optima Blue Top battery – 12v house battery
4x4 Labs Front Bumper
4x4 Labs Rear Bumper
Custom DIY Kickout Rock Sliders
JW Speaker 8700 Evolution 2 - 7" Round LED Headlight – Black
Installed 2008 BMW 328 Sport seats
Old Man Emu Medium rear / Heavy front
24 Premium Black Closed Acorn Lug Nuts
Gorilla 5 Black Closed Acorn Locking Lug Nuts
5 - Mickey Thompson Classic III, 15x8, 3 5.8 BS
5 - BFG MT KM2, 33x10.5x15
Installed 4x 1” aluminum wheel spacer
Drive shaft slip joint clean up + lube (rear)
Knuckle rebuild - Wheel & Trunnion bearings
Front brake rotors
Front brake pads
Rear brake rotors
Rear brake pads
Front hubs spacers from Radd Cruisers
Front Aisin manual hubs
Front wheel studs
2 Deka Gold Batteries
Siberian sway bar Bushing
Tie rod end (RH)
Tie rod end (LH)
Steering rod end (RH)
Steering rod end (LH)
Oil - shell rotella 5w40 (~9 quarts)
Oil filter - Toyota OEM
Rear universal joints
Adjusted injection pump - increased fuel 1/8 turn
Valvoline Maxlife Synthetic ATF Dextron III
Meter, hood assembly cover
Gauge bezel - custom fabricated
A/C tensioner pulley
Hella Black 24v 30 Amp Relay (used 3 relays)
Split Bus Fuse Block for 2 sets of 6 Fuses
12 VDC 5-Pin Relay Socket
Dash Bezel
Power Steering Pump Rebuild Kit
Thermostat
Thermostat gasket
Water outlet gasket
Outlet radiator hose
Inlet radiator hose
Inlet hose clamps (2)
Outlet hose clamp - radiator side
Outlet hose clamp - engine side
Valve cover gasket
Intake manifold gasket (position #1 frontmost)
Intake manifold gasket (position #2-6 need 5)
Intake manifold bolt rubber gaskets (need 12)
Intake manifold nuts (need 12)
Intake from turbo gasket
Injector nozzle seat gasket lower (need 6)
Injector nozzle leak pipe gasket upper (need 6)
Water pump - Aisin from CruiserOutfitters
Diesel Injector Overhaul
Radiator Overhaul and Re-core
Power Steering Pump Overhaul
Oil seal – camshaft
Hose - resv to steering pump
Hose - resv to steering pump - clamps (need 2)
Hose - crush washers - pressure side (need 2)
Power steering pump main bearing
24v relays for headlight wiring
The picture aren't loading very well for me... if you can't see them go here for the entire album.
I wanted this when Steve still had it, GLWS!
Holy wow, what a beauty. Amazing build, awesome truck. Whoever buys this is getting an incredible value. Turnkey truck ready to go.
Agreed. Sol did the bang bang work. This truck is SOLID Motherfvcking pimp JDM Land Cruiser action. We did some business together so I know there were some quality OEM parts used.
Sorry to see you sell it Sol.
Super nice truck. I would think it would sell quickly in CA.
Thank you! I would think that being a CA titled truck would be a BIG plus. It's getting harder and harder to get cool cars into CA. The new owner just needs to transfer the title into their name.
I've seen this one in and around Livermore and Pleasanton, good luck with sale but I'm not sure how you can top this outstanding job on your next project!
Thanks...! It has been a very fun project. I'm sure I will look back so day and say why did I sell this one.... :)
Do the Safari kits come with optional boost choices? what boost is this running? cable lockers?
You can adjust the boost up or down on the Safari kit. I am running the preset 10 PSI. No lockers, open diffs, I never planned to wheel this cruiser.
This truck is VERY fairly priced for what it is.
good luck with the sale and great job on it.
Thank you... I've taken a.lot of pride in building this cruiser. I hope the next owner enjoys it as much as I have.
