Do I detect a belt and suspenders here? It looks like a mat on top of a mat ........
For a man of advanced age, you have pretty keen eyesight ........Do I detect a belt and suspenders here? It looks like a mat on top of a mat ........![]()
Waffle iron?View attachment 1242717 First thing on the roof rack.
Not just a waffle iron but a deluxe waffle iron.Waffle iron?![]()
Electrical Gremlins.....
Rob has converted all of the interior lighting to LED however the center dome light failed recently. Upon inspection, the power wire had completely burned through. A "short" would have been the first suspect however all of the dome lights utilize the same power source and ground in a similar fashion and they were all working normally. The faulty dome light, once rewired, worked on the bench and the power in the dome assembly tested normally. (This is where having a sharp electrical guy pays dividends.)
The previous owner had undoubtedly used a screw driver at some point to remove a faulty bulb and in the process, had ever so slightly damaged one of the tabs that holds the factory bulb. Rob noticed the imperfection and once corrected, all of the LED dome lights are now shining away.
I need to get these done, how long was the wait? Ill add it to my ever growing excel spreadsheetView attachment 1245580 The only interior item that wasn't near perfect were the sun visors. That is now corrected ..... Thanks Onur
Approximately 2-3 weeks.I need to get these done, how long was the wait? Ill add it to my ever growing excel spreadsheet
