Build 1989 Toyota Land Cruiser FJ62 Build
Member Build Threads
looking really good! I like the red grille. I think it would look even better if the trim around the headlights was black also.
I was thinking about it too glossy black with black handles and air vents ?
Steaming the carpet to make it sit in place, I found a place that will redo the seatbelts owned by veterans $500 for all 5 seat belts they’ll remanufacture it in ivory color for me if they’re good I’ll share the contact here once I get them
So I made a boo-boo but hopefully it’s a good lesson for those who don’t know
I installed the torque converter on the flex plate then mated the transmission
Good thing I haven’t started it or cranked it or else I would destroy the transmission pump inside
First install the torque converter on the trans and spin it until the notches line up and it’s seated in correctly then put it on the flex plate and torque it down in a star pattern
Now I gotta take the trans off 😂 oops
...where did you get that steering wheel from? Mine has that totally smooth texture and it spins with whatever holds the rubber to the metal frame of the wheel. TIA!
It came with the truck, send me a pic of yours
Why do you always have to say something so accurate that I haven’t thought of
Lmao
I guess now we need fender flares
I've got a set I pulled off my 62. They are likely the Aussie repros. Pretty good condition. Holler via PM if you want
Ian
