1985 BJ70 CND refubishing and modifications
test fit on the truck
these will give adaquate light for night welding or setting up camp.
the rear has the 2 X 120* on the outside corners and the 8* spot in the middle to help when backing up.
testing front bumper lighting
light force driving and fog lamps
then adding the 20" LED "spot" ... not sure i like the spot but easy enough to change out later now that it is mounted.
lights off in the shop and the wall is as bright as if they were on.
i am happy with the results of the floods.
that is it for now.
for future reference: RS999005 rear RS999017 front
Based on the above photo it is very difficult to understand how soccer is not more popular in the U.S. :D
we had to add steel bars for the strobe light to attach to ... tap the aluminum, SS bolts, done
next was modifying the 20" light mounts on the front bumper.
cut the feet off
drill adjustment holes for the main light
drill and tap the side for the mounts
trim the rubber cushions for shock absortion
mount the adapted plate
install adjustment bolt
install the light
and done
nice clearence with the Light Force and the 20" driving
next up is finishing the wiring for the lights ...
weather proof connectors, wire loom tied safely out of harms way.
That brush bar is a work of art.....
Are those amber lights ( Light Force) legal for road use?
in Canada, as far as i know, as long as the lights are level or below the head lights and aimed properly then you can run them. light force is DOT stamped.
it is illegal to run lights facing forward above the head lights ... but seldom do any charges get laid. if you are an idiot and run your roof mounted off road lights on while driving down the road ... you deserve the hassle.
These good ole boys down here could negate the spirit of that law by jacking up their F-350's to the point where it takes a step latter to get in it.:)
The lights are so high up in the air you think it is a UFO coming down the road.
here we have a head light height law. the center of the head lights can only be (if i remember correctly) 36" off the ground.
it makes sense, when on the road ways you have to be considerate of other drivers. off road, then 'light up your world'
I have been hearing CVSE does not like the truckers who run them. If black covers are not on at the weigh scale you can get fined. Which is stupid because if you had a brain you would only turn them on if there was no oncoming traffic on the highway.
the 20" driving light is being wired in with the high beams only. low bean, no driving light.
the fogs are independent since there are time when you want the head lights off and just the fogs on.
got the winch plate back from the water jet.
fits like a glove but never grabbed a shot of the bumper temp mounted.
will finish up the support bracing and attachments on Monday.
3/16 or 1/4 plate?
Looking good...:beer:
Rob
