1985 3FE Swapped FJ60, a Refresh
I'm very likely to go 235/85 soon and put these 255 km3 on my 40.
Please feel free to clog it away, I’d love to see more pictures of Clark.
@johnnyshaner Has 235/85 Geolanders on his 60, which look’s pretty great.
As well as @Ian Crawford with KO2s.
My understanding is also that since BFGs run small a non-BFG 235/85 would probably be a bit taller.
Another thing is that 235/85s are a lot easier to find than a 33x10.50, and they’re less expensive. I believe probably the best tire for these trucks is the 255/85r16. However, those are more expensive, and basically only available in a mud terrain.
There’s also very limited options for the 33x10.50 at this point.
My only slight hesitation is that, as @gimme a 60 point out, it would be a downsize, on paper anyway. But since my KM3 33s only measure 31.5” tall, I don’t think I will really lose height.
You've researched and thought this out clearly. Totally right on the cost too, I forgot to mention that, but it was a factor for me when I was looking.
Slammed on a Y-pipe that @HemiAlex sent me tonight, which was apparently on @Kleatus 62 before that. The truck should go to the exhaust shop soon.
There’s oil on the engine. I’ll track down exactly where from later, slightly irritating considering with the amount of time I’ve spent to correct just that.
Don’t worry. Oil in the engine is normal. It’s when there isn’t oil in the engine that things go bad 😉😂
Ran up to the Birmingham Vintage 4x4 Swap Meet and Greet today and snagged a set of 70 series wheels from @Bama4door
Adjusted the valves hot, adjusted the rear brakes. The parking brake is working now, brakes may still need some adjustment as the pedal isn’t as firm as I would like, but it stops.
Drove it a little distance. It’s extremely loud and sounds awful on just the Y pipe. @Godwin will take it to the exhaust shop later this week. We still need to put the bullbar back on, then I’ll be driving it again. The oil leak is coming from the bottom of the timing cover. I’m not pulling the crank pulley and timing cover over a little oil.
Adjusted the valves hot, adjusted the rear brakes. The parking brake is working now, brakes may still need some adjustment as the pedal isn’t as firm as I would like, but it stops. View attachment 3439223
Before I take it the exhaust shop I'm going to drive it up the road with the open exhaust and really wring it out. I'm thinking redline in 1st, 2nd, and 3rd gears.
And still won’t break the speed limit.
That Y pipe was fabricated in New York, was on my 62 for years and had passed through dozens of states, resided in a few more, and was removed here in Missouri when I did my LS swap. Hopefully the 02 sensors were still intact by the time it made it to you? Quite a circuitous route to end up in AL, via a Texan traveling from... was it Minnesota? who stopped by and left with some parts.
I've been researching and thinking about tires since my KM3s are pretty worn. The current size on the truck is 33x10.50r15, they measure to about 31.5" tall. My idea is to move to a 16" wheel and most likely go with 235/85r16 (32x9.25") pizza cutters. This would put the tire height about the same as it is now or possibly slightly taller. My dad's 60 runs 2500 RPM at 70 in 5th gear with 4:11s and 255/85r16. I believe with a 235/85 in 5th with 4:11s my 3FE would be spinning at about 2700 RPM at 70. The 235/85r16 in an A/T may lead to slightly better MPGs as well, due to less unsprung weight and a less aggressive tread. Also with a 235 there would be less drag due to the narrower width (as if that matters on a 60). Everyone who runs 235/85r16 seems to really like the size, but can anyone weigh in on it?
I ran them for a long while on my 62. Lots of available types/ brands and all but one I've ever seen was load range E (not a bad thing). They were very close in height to the pathetically sized 33x10.50 BFG's. Wish I could happen upon some 70 series wheels...
2700 at 70 is fine. That's what I was at with my a440 and 4.88's with "33" BFG's, it's almost exactly the same final ratio as H55 and 4.11's.
O2 sensors still intact and apparently good. When we ran the 3FE with only the exhaust manifold the CEL lit. Now with the Y-pipe and O2 sensors hooked up no codes are coming up.
Trip to the exhaust shop today. Afterwards I drove it a couple of miles and the 3FE pulls well. I think that for a 60 that's staying close to OEM that the 3FE + H55F combo is the best (or maybe a 2FE, I just haven't driven on). The 3FE easily runs up to 3500 - 4000 in 1-3. I it 60 in 5th and it was still pulling strong; should run 70+ without issue.
I put 80ish miles on the 60 today. It’s running about 2100 rpm at 60 mph in 5th. The old KM3s are loud and squirmy on the road and it’s driving me nuts. The idle is about 900 rpm, but it varies slightly to about 950 rpm.
The rear brakes also keep over adjusting themselves, to the point where I can barely move the rear tires when it’s off the ground, I’ve had to back off the star wheel twice in the past two days. I’m hoping that this will cure itself after the the new shoes are worn in.
I’m going to replace the evap core soon so that I can have working A/C.
Overall it’s doing good and I’m pretty happy with it.
I think the 3FE+H55F is a fantastic powerplant combination for a wagon.
We let nothing go to waste.
All that stuff will be gladly given to anyone who needs it.
I started on my evaporator core replacement tonight. After some irritation and about an hour of wriggling I got the box out.
It was pretty nasty.
I have a clean one to go back in with a new Denso expansion valve. That will be done tomorrow.
The evap core is back in. It was about half as irritating going back in. The expansion valve I had is for a 62 and is different than a fj60, so the old one went back in.
New filter drier.
We’ll pull vacuum on the system probably tomorrow and check for leaks before charging.
