OlYellr
If I understand what you said, you stabbed the distributor per FSM (compression stroke etc) - used the timing light and the bb shows up on the pointer, and the timing gun says 7. Correct? You then change the gun to 11, and rotate distributor until the bb at tip of pointer. Is that what you are doing/saying? If so, that is only 11 not 17.Now I gotta figure out my vacuum secondaries. My linkage trips the lever for the secondaries ( right at WOT) just enough to barely crack it but they don’t open up. I tried the paper clip and it doesn’t move after a drive and trying a few WOT
Also… If I stab the dizzy with the BB in the point then I’m already at 7* of advance timing when running and the light flashes when the BB is in the pointer … correct?
So if I add 11* advance to my timing gun and then advance the dizzy until the BB is in the pointer again that would be 18 total degrees of advance time … correct ?
IMO, chase the secondary later. Some carb kits gaskets don't have the hole in the proper spot for vacuum to route internally in the carb for secondary. ETC. I have no secondary on mind, and sometimes I think I miss it (been 2 years), but I drive mine from the flats of the plains to Overland in the Colorado Rocky Mountain Passes - even then, don't really miss it (yes I have to change my timing when I go to the mountains - and it all impacts starting and running). Sometimes going up a long hill, I think it would be nice to have. Anyway, chase one issue at a time is my opinion.
I had the big distributor when I got my 40 in 2021, and got the 2f distributor from racer, and put in the Pertronix electronics in it. The stock points in the distributor worked fine too, but at the time my mind instead on electric vs points. Works fine - I too have a 1980 FJ40. my only issue in the Pertronix conversion - the supplied bolt was too long and it hit internally when the vacuum advance was happening - quick swap, fine now. Anyway, since I knew I would be going into the mountains and need to adjust timing often, went to the smaller distributor like stock that would not hit the engine bits while rotating. Something to think about depending how you use your rig.
79emission%20schematic
