- Thread starter
- #141
Road report …. Kinda of !!!!!
So got everything wired up and commenced to getting her timed. I think I possibly got her off a few teeth off as I couldn’t even get her down in the teens on timing as the vacuum port on the dizzy hit the oil cooler line and wouldn’t retard any further plus I was running out of adjustment anyway.
Now I stabbed her at 7 BTDC on the compression stroke. The button and the #1 on the dizzy ( as I marked it on the rim ) were pointing (when seated ) pretty much at the #4 spark plug. I’m thinking the dizzy is off a hair though.
I followed this procedure …..
I also got to tweak my throttle linkage assembly some as it’s not returning 100% back to 0 throttle. Think I got the levers adjustments/lengths a hair off as I was concentrating more on making sure it tripped the secondary at WOT.
The good news is my carb fan does work !!!! When I got back from a quick test drive…. The fan came on and shut off !!!
At least I did something right !!!!!
So I think I’m gonna re-stab the dizzy and see if that gives me some more adjustment and make sure I got it correct and not off a few teeth.
Should I consider stabbing it at TDC instead ?
Also which port is for the Vacuum Advance hook up or are they to the same single diaphragm and you just plug the unused one ?
Finally… what the heck should I do with these vacuum nipples on top of the distributor???
