Build 1975 Red (green) Money pit
I was just going to remove it and plug each end .
But I had another one I just put in its place.
My question is would the one I put on the engine now make it run any different than the old one?
Sure ,
the replacement manifold u just swapped out was the heat riser flap freely moving & did / do u have the bi-metalic
spring correctly in place ?
if the flapper stuck in the cold engine position , after warm up it would super heat the bottom of the intake up and
cause a drivability issue , atomize the fuel too soon , crAck the bottom of the intake etc .......
all this could happen
also , i see some missing bolts in your photo that sandwich your manifolds together , that would cause issues possibly
your egr block off plate appears to have a broken stud too & nut too
the drivability issue could be a vacuum leak at manifolds to head as well
check all these topics Tommy , make sure everything is tight and solid
Well, next project... Purchased the necessary parts. So my first welding project is going to be interesting..
2x2x0.25 tubing, and going to use 3x3 angle iron butted together.
I’m looking forward to seeing your progress on this. I want to do something similar. Where did you source the spindles?
Anyone know where I can find this part that screws into the head that fits this temp sending unit? The dia. Of mine is smaller...😕
You need the piece that threads into the cylinder head itself? I can throw one in the box with your carburetor.
What would cause oil leaking out parking brake? I see fluid slung up above parking brake...😡
Just powered through the build. The 40 has turned out great. As for the oil on the parking brake, it’s likely the output seal on the back of the transfer case. If that seal is still good, you may get away with just putting a layer of RTV on the splines just before sliding the parking brake onto the output shaft. Don’t forget to drain the t-case first or you’ll have a big mess on your hands.
lol... I wondered about that. Noted, drain case! thanks
I do have a new seal, so guess I have something to do Saturday.
Got a lot done yesterday. Cut and drilled the bottom bracket. Welded spindle to the bottom 2x2. Had to take it slow on the drilling, but it worked out perfect.
After I welded the spindle to bottom 2x2 I assembled the spindle to get my length of the top 2x2. Drilled the 2 1/4” hole on both ends and welded it in place to the spindle. The made side it was even all the way across.
I cut thru the solid spindle on the bottom and went thru one cutting wheel..😂
Built and drilled the brackets to mount to the rear crossmember.
Sanded it all down and cut the top Swingout in the middle. Need to build the overlap piece for the latch.
Going to work on the tire mount today and mock up the brackets.
Guess I will be painting next weekend. 😕
