1974 FJ55 Build
Can anyone recommend an aluminum radiator? One that would work for the 4bt as I don't want to buy twice. Not sure of what dimensions for the 4bt.... I'm starting to run extremely hot. Here in Baton Rouge I'm in traffic a lot.
I remember the 55 running hot at the end of last summer. One thing I wanted to try was to run it with the hood off and see if that makes a difference. I wonder if the hood doesn't allow the heat to escape. If so, a bigger radiator might help, but there might also be other solutions as well.
You're looking at 24" to 26" across and @ 19" high. I just bought a Griffin which looks sturdy and made in the USA, Ron Davis makes top notch ones. I would talk to the actual manufacturer in order to get what you need. J Mack went through a lot of trial and error before finding the right combination for his setup. There are others, too depending on your price range, which can get very high with alum. radiators.
I wonder if that maybe some of my issue. I'm getting 22"Wx19"Hx2.5". So already I'm a little small from those measurements.
I've been using Jmacks build thread as a sort of Bible for my 4bt... he's definitely done the trial and error and I can't afford that trial part. I'd be down a wife for sure
Mosley Motors makes a bolt in for the 55. Can get it with electric fan or without.
That was my plan! I went ahead and ordered that radiator. Thanks!
Now I need to get a clutch master cylinder. I order thr Aisin CMT-041 from one company but apparently their "inventory" was wrong and they just refunded my money.
Look at how I did mine. Make some alum. blocks mounted in between that channel and draw up some brackets to screw to the blocks. Several different ways you could go.
