1967 FJ45 Long Bed resurrection
Old fuse block and new one. Old didnt seem to bad, i found the cover when cleaning it out. I will keep it because its original.
That’s an interesting fitting. Doesn’t have a spot to put the sensor. Here’s what I have on my 1F and it obviously has the hole to screw in the sensor (which I need, not sure if they are still available OEM?). Maybe you need a different fitting that still has the valve for a heater hose.
This F135 does not have any other holes on top Like an F155 does. My truck has a sensor on the top of that fitting. I am not sure if water is even flowing through that though. It’s been unhooked on mine. Probably all full of sludge. I’m going to get mine running and then at some point pull the valve cover and make sure that’s all flowing properly.
Yeah, those will work:clap:
