My mechanic who is a ex-airplane mechanic was telling me about the green paint they used to douse the insides of the planes with to prevent rust?
You're talking about Zinc-Chromate. It's not used on airplanes to prevent rust, it's used to prevent corrosion. I kind of doubt it would be effective on steel. If anything, I could easily see it leading to worse rust on steel, as it's pretty porous.
I personally would use weld-through primer in the areas you can't access. Once they are closed back up, the weld through should be able to protect it long term--as it won't be exposed to the elements really. I might make extra sure there are drain or access holes to preclude pooling and eventual rust, but inside a closed area--I think a weld through primer should hold up great.
Buckroseau simply used DP50LF instead of a weld through primer, and I'm half tempted to try that myself soon. Just because I'm using DP50LF anyway, and if it deals with the welding allright, then I guess I'd be happy with just using that.
Looks like fun!
Dan
