Same here. 63 with stamped bezel. Then you can sell me the 25 bib. You beat me to it!I agree, 63 front bib.
Split window was installed back in VA before I drug her out here. Iām just waiting on you to get one so we can compare notes. Due to a lack of defroster hole(s) on the later model split windows I wonāt be driving it much in the winter in CO. They also use sodium chloride brine to pretreat the roads which is a hard NO. Although I do have a clamshell heater for it since I was never able to find a front cover for the Eaton heater that it came with.OEM, except add the split windshield. Do it, do it, do it!
Save the original windshield, maybe even paint it to match the new truck color for a future owner. It will be plug and play.
Perfect application for a split window! Being a fixed top, it will allow some airflow!! Now a double split window!!
Iām hopeful the flow from the front windows thru the cab and out the back is enough? Time will tellā¦Perfect application for a split window! Being a fixed top, it will allow some airflow!! Now a double split window!!
Spring time push! That will be a nice benchmark to get that motor sitting in the chassis.Iām hopeful the flow from the front windows thru the cab and out the back is enough? Time will tellā¦
Todays project get the engine out of the bed of the truck and truck spun around and maybe just maybe set the engine in the frame rails.
I have a love/hate relationship with governmental and institutional budgets. Love when I get something for a smoking deal (engine lift) thanks CU Boulder! But I find it absolutely ridiculous and wasteful to replace things before you normally would due to not using all your budget and then not being allocated it the following year.
Nice! Iām sure the Yoder family appreciates the support! I really appreciate you stopping by! Nowā¦what did you actually think of the donut?
You can use a shop vac and it will pressurize the system and allow it to shift. Weāve put the transfer case in low and high, locked the hubs and engaged the 4 wheel drive using a home made adapter and shop vac. For those of you wondering itās the hose closest to the firewall that engages the four wheel drive. We know this worked as the front driveshaft locked up. Iām just a redneck from SWVA.Alright guys I need some help/infoā¦
Is there a way to manually override the vacuum transfer case engagement system on the ā67 FJ45?
Could we use air pressure to actuate the valve inside or does it have to be vacuum?
Or can someone tell me which line you apply vacuum to for it to engage the transfer case?
