1963 FJ40 FST Q's
Boise, Id
1963 FJ40 FST Jackasstoration
Finally getting around to working on my 1963 FJ40.
I decided to remove the floor-shift 4spd that was installed about 15 years ago by a local 4x4 shop and put a column shift 3 spd back into it. I'm using a 3-spd and tcase out of a 1965 FJ45 as the donor.
Question 1. How are the vibration dampers on the bell housing ears supposed to be mounted? SOR's schematic shows the PS stacked, two under the ear and the DS sandwiched, one below and one above the ear. If I install them this way, the DS mount doesn't make contact with the damper. I've got it in like this now, and it seems to be supported on both sides.
Linkage
Question 2. My shift linkage that was left is different than what I recall was on the 1965 FJ45. This thread:
https://forum.ih8mud.com/40-55-series-tech/228873-early-40-series-3-tree-linkage.html
shows what was on the 1965.
Mine looks to be different, hence why I'm here in the 25 section asking. So I guess my question is, will this work with the transmission I'm installing, or do I need to change it out with the newer shift assembly?
I managed to replace the rear main seal and oil pan gasket today. The old main seal was so brittle, it just crumbled when I pulled it out.
Next on the to-do list is to weld in a rear cross member, the original one having been torched out to install the 4spd.
Question #2 Looks like a mismatch. 1963 was a changeover year for transmission. I'm guessing your column shifter is for the earlier switch which was design to shift the early three speed with shift rods coming out the side of the transmission. This used two piece shifting rods instead of one single and one double on the later top shifting transmission. If I remember I can scan the diagrams of both early and later transission from the FSMs
Question #1 I would have to check a few motors to be sure but the pictures look right.
Figures. I guess I'll go ahead and stick the transmission in and see if the shifter linkage will work. If not, then I guess I'll need to pull the steering column out and change it out with the later stuff.
Or, I could try and locate the correct transmission, but that may be a bit difficult.
Dan
I've already emailed Dan these pictures, but I believe this is the correct configuration for the mounts:
3/3 F engines from a range of years which I have access to are mounted this way.
Dave is right. I was looking at where the mounts were located not the order. The passenger's need to be flipped to match daves's.
If you still have the column from the 65 that would be easier than trying to find a good early one. Seems about half of the early running FJ40s have had them changed to a later transmission. The others are probably well worn. I do know of one in great shape but I know it's not for sale.
I learned another difference between early and later model 40's today. The cross member aft of the transfer case is shaped different.
I had two cross members from mid 70's 40's laying around. I ended up having to use parts of both to get it to look right. It took a bit more cutting and grinding than I expected, and it still needs some more grinding and some paint, but it's in.
If you still have the column from the 65 that would be easier than trying to find a good early one. Seems about half of the early running FJ40s have had them changed to a later transmission. .
Agreed. And you will be happier with the system [read;more likely to leave it intact] with the later column shift anyways.
Your name came up a couple of times at the 45 run last weekend Dan.
AND I realized I could have called you about a visit.....as I was leaving Owyhee County last month!:doh:
What were you doing in Owyhee County?
Wife and I were on a 15 day mega roadtrip.NM,KS,MO,IN,OH,MI,IA,SD,MT,ID,NV and back to CA.
Actually ended up spending the night in Twin Falls!
I had to pull the old column out as I had remnants of the side-shift linkage left from the 4-spd conversion. The shop that did the install of the 4-spd, broke the shifter off the column.
I think I've got it all hooked up and shifting correctly.
So now I'm going to change out the front and rear ends. I have the '65 FJ45 front and rear ends but they are pretty hashed, all the brake lines need to be replaced and wheel cylinders rebuilt.
I think I'm going to stick a 78 FJ40 rear end under it and the front end out of my 73 FJ55. Both are in excellent shape and don't need any brake work.
The axles that are currently under this are out of a 72 FJ55 and half the wheel cylinders leak.
I'll need to find drive lines next. I've a pile of them and not one fits. I thought I had at least a front drive line out of my 45 but it seems a bit long. And of course, the rear drive line from the 45 is about 4 feet too long.
