1962 FJ40 / Picture / fjfjfj
your old bumper is period correct. the lack of holes tells the story. if you look, your new bumper has many more holes because it is setup to accommodate every option available. early models only had holes for early options.
also, annie only has single sided turn signals, which we are fairly sure is correct vintage.
Mine does have the front double lights.
I took the bumper from a 1968 to put on it do I know it is not correct vintage from the factory.
I understand that 1962 was a transition year for the Landcruiser. They used FJ25 parts and FJ40 parts on the same vehicles.
Sent from my iPhone using IH8MUD
Holy craps that is AWESOME looking ! Hope to get mine looking like that some day. Is the FJ25 area the best place to find the parts I need for my 1962 ?? I'm in for a long haul finding things, but I'm even more determined to restore a '62 due to the rarity !
Is the only place I can find my VIN on the engine side firewall? It's the only plate I've seen so far. I'll post my VIN # later tonight if you're interested.
yes, 25 section is best, 45 section is also good.
Your VIN# is 16526 :p
Interestingly enough, nuclearlemon's '62 is only 3 digits off!
They probably left Japan at the same time.
Hello HuntFishHuntFish,,,,,,,,,,,,,,Thanks for the nice comment. Yes, FJ25 section great for parts and even better for advice. Really looking forward to seeing your restoration. Didn't mean to sound negative on your thread. Sounds like your on a mission. I like that. Good luck with the project.
I have never noticed any difference in a later style starting in 62 to the start of 75. Besides the holes on the bottom of my FJ25 being in a different location and only using two carriage style bolts on each instead of three those were the same also. Two locations for the license plate bracket. One in between the frame horns and one to the right side when a PTO winch was installed. Two holes for the PTO winch. Then holes outside the frame rail for the fog lights. License plate bracket, fog lights, PTO winch, what other option were available? My 10/76 has more holes but I can't swear it is original to the cruisers. A friend of mine gave me his bumper off of a 1/75 FJ40. He put a channel iron bumper and Warn winch shortly after buying the cruiser new. I still have the bumper. Easy for me to tell which one it is. My 68 which I bought in 74 had extra brackets on the ends that ran back and bolted to the back holes for the PTO winch. They look so professional made I thought at the time they were OEM. I drilled the 75 bumper to use them. :bang:
Also noticed on pics I got from fjfjfj the inside of the rear sill is different: mine has no reinforcements in it.
If by reinforcements your talking about the U shaped channel that runs against the bac and roll with the outside corner than your has been changed. That U shaped channel goes back to the FJ25 and maybe earlier. Never seen a BJ in person to look.
61 was the closest to the FJ25. Inlet on the apron for the oil bath air cleaner. Large gas cap. Early front bumper. A bracket welded to the front of the wheel wells for the arms on the front of the jump seats. Jump seat arms were lower than the FJ25 but still had arm rests on the front.
Two 61 FJ40s VINs 1FJ40~10202 ahd 1FJ40~10939.
Two 62 FJ40s one is the soft top tub I picked up. Was sold as a 63 but because there was a old insurance card inside I know the VIN. Won't post that one since the frame, VIN plate and title were sold to TLC to made into a Icon. I didn't sell it just bought the tub. That one is a little lower than 15000. Second one is 2FJ40~15956.
JohnnyC and I figured Toyota started the FJ40 VIN numbers at 1FJ40!~10001. The production numbers don't add up to eleven thousand units in 61 Then only in the 16,000 range in 62. What I find strange is a lack of VINs in the 11/12/13 thousand range. Curious were sales so bad in the US that after importing a couple hundred 61s Toyota waited until sometime in 62 to import more? :meh:
I have never noticed any difference in a later style starting in 62 to the start of 75. Besides the holes on the bottom of my FJ25 being in a different location and only using two carriage style bolts on each instead of three those were the same also. Two locations for the license plate bracket. One in between the frame horns and one to the right side when a PTO winch was installed. Two holes for the PTO winch. Then holes outside the frame rail for the fog lights. License plate bracket, fog lights, PTO winch, what other option were available? My 10/76 has more holes but I can't swear it is original to the cruisers. A friend of mine gave me his bumper off of a 1/75 FJ40. He put a channel iron bumper and Warn winch shortly after buying the cruiser new. I still have the bumper. :
dont' forget the two holes in the front where people mount the madonna boob looking rubber cone bumpers. ;)
later models have more holes, foglights in different local (iirc), bracket for hand crank, not sure what else, but i remember getting a new bumper for my 45s bashed up one and being a bit dismayed by all the holes. i'll try to remember to get a pic when i get home
Forgot the bolts hand crank bracke, my grey 25 still had part of the bracket. Not sure when it happened but at some point Toyota added more holes to bumper. Don't think it was for options that were offered here. Don't believe the fog were offered or if they were they were trying very hard to sell any. The ones that SOR is or at least was look OEM and the price wasn't bad. Would have picked up some if I didn't have a couple of sets already.
Hi LITP. I meant reinforcements inside the U channel. Don't want to hijack this thread so i posted pics in my rear sill thread.
bumper pictures. early vs. late (on the late model, the two groups of four in the face were drilled after the fact)
