Meshal
Thanks, everybody, for the input.I went with the 13BT; well, I put a deposit on it.
I drove 3.5 hours to check out the 3F in person. In the listing pictures, it looked like it had just come out of the manufacturing plant. However, after a quick check, I found some red flags: there were 1-inch spacers on the tranny skid plate.There were also plates with four bolt threads sticking out on each side of the frame by the transmission, possibly used to fix a bent frame?
The left rear gate didn't line up, and the right one hit the ARB bumper on the right corner. This could have been an issue with how the bumper was mounted, but given the other flags, it seemed more likely that it had been rear-ended.
The 13BT was 4 hours away from there, so I drove over, checked it out, and it's in great shape"
Where can I find more info on this?….the best upgrade to this engine is a turbo upgrade. Makes a huge difference in how it drives, so much better.
That shop looks very familiar.
Thanks!There are a couple of options depending on what you want to do. The factory turbo Toyota used on the 13bt is too big, so it’s a bit lazy and laggy. These upgrade turbos are sizes right and make it drive much better.
Bolt on turbos:
Gturbo - out of Australia, makes great turbos lots people use them here, about $1,600US plus shipping.
13BT / 14BT Archives - GTurbo - https://gturbo.com.au/product-category/gturbos-for-toyotas/13bt-14bt-15b-fte/
Munro turbos - builds custom turbos out of Australia, bolt on, highly used in aus, $900ish to $1500 plus shipping. I was going to use them, but went a different way.
munro racing turbochargers - https://munroracingturbochargers.com.au/
Non-bolt on but possibly better…
Holset he221w -that’s what I’m running. Will need some mods, adapters to work, intake/exhaust , works excellent.
Td04hl pretty much same thing as Holset, needs intake/exhaust mods, oil/drain mods , work great
These 2 above are cheap, but require work like I said. If you like to tinker and mod, they will be awesome. These are more modern turbos compared to the bolt on ones, but nothing wrong with the bolt on either.
IMO, once you upgrade the turbo you have to upgrade the exhaust. 2.5” is fine and easier to route but it will help with EGT and airflow.
You really can’t go wrong with any of the above options and it really makes the engine feel and run much better. Feel free to ask away on questions.
That Bj71 looks great! Welcome to mud!
