100 Series NAV Delete – True Standalone HVAC Solution (OEM+)
Enthusiast Level vs. OEM Level
  • Enthusiast
    Votes: 21 21.0%
  • OEM
    Votes: 79 79.0%
  • Total voters
    100
  • Poll closed .
Progress Update
Core hardware direction is now locked and we’re transitioning into schematic and PCB.
v1 uses a dual rotary setup for TEMP and FAN (with push-off on fan), supported by dedicated physical buttons for AUTO, A/C, RECIRC, MODE, and FRONT DEFROST. MODE cycles through vent positions with indicator feedback.
Feedback is kept simple and OEM-focused: a small center display for temperature only, mode indicators (Face / Bi-level / Floor / Defrost), a fan level LED bar, and active-state indication on key functions.
System behavior is designed to mirror factory AUTO climate operation, with proper integration into OEM dash illumination for dimming.
edit: this is AI generated but using our specific parameters on what a finished product would look like.
With this layout does the temp knob center at 72 and turning it changes the auto temp?
Progress Update
I'm happy to be an early adopter and supporter for a v1 on a 2007 land cruiser
Progress Update
It would be worth making the temperature display selectable between Fahrenheit and Celsius to cover global markets, maybe through a key press combination.
Edit to add - now seen a few other have commented this!
Moved into PCB design
Brought in dedicated automotive PCB experience for this phase. Hardware locked in now with a focus on clean, stable operation in-vehicle from the first revision.
Once boards land, it goes straight into bring-up and in-vehicle testing.
Progress has been steady behind the scenes
Major components are placed and routing is in progress, with heavy focus on power distribution, grounding, and noise isolation for real in-vehicle conditions.
Designer comes from ultra-high-performance automotive electronics, so the expectation here is production-grade reliability on the first revision.
@LJE handling initial 3D Scans & CAD for physical constraints and fitment.
LX gets a true OEM-style integration into the cassette slot.
LC is slightly different, will require a faceplate to adapt cleanly.
Both will function the same.
Initial small run being planned.
Quick questions. Why would LC need a face plates vs LC being in the cassette slot?
I've been following along and think (thought?) I was keeping up. But can you briefly explain what happens to each of the these sections - since the Toyota engineers decided to spread controls all over the place. Also, THANKS for taking this project on!
The only thing that @Anarchy is changing is replacing the stereo in #5 for HVAC controls.
Everything else will be unchanged. However, this WILL require you to install an aftermarket head unit, or relocate the stereo unit.
Where would the aftermarket head unit go?
I'm in for one.
