you will just go limp Follow along with the video below to see how to install our site as a web app on your home screen.
you will just go limp you will just go limp
The newer 100 series mid-pipes should be ready to ship the week of Dec 17th.
Looks like we have 2 coming your way. One for one of your customer's rigs and one for your truck
We're happy to be able to offer performance parts to such a great community of owners. The donor vehicle is being dropped off around the new year for the header mockup and testing. I'll keep you guys updated on the progress as we get to the headers as it seems many people are excited to see how they turn out.
up or else my money goes to the guys that put their
out there on the chopping block. That's truly Made-In-America.Nut up orup or else my money goes to the guys that put their
On the number of welds. This is how our production usually goes with most of our products:
1- prototype and r&d work done with pre-bent mandrel 180 sections of pipe that are cut and shaped to fit the way we want.
2- first few production runs are built using pre-bent mandrel bends that are hand cut and hand shaped to our precise jigs.
3- we have our pipes 3d scanned and each section of pipe is mandrel bent as one piece by a highly accurate computerized CNC bending machine. After this batch is ready then all assemblies going forward are built using the custom bent sections.
Either with the pre-bent mandrel sections or with the cnc mandrel bent sections the quality and fitment is 100% perfect, strength is the same, and longevity is the same. We TIG weld all of our assemblies with 308L, 100% pure argon shielding gas, and all piping and flanges used are true 304 stainless steel.
I have a question about the "Mandrel Bent" exhaust which is where this system is supposed to end up.
I looked over the EMS website and none of the exhaust systems were mandrel bent as I think the term applies?? All the systems I looked at were welded up piecemeal.
Can you advise if this system will be mandrel bent and when?
if you look closely at the kit pics, you'll see that the sections of pipe that are tig'd together are cut sections of mandrel bent pipe and not crush-style bends that would restrict flow. They are some seriously free flowing pipes...and in my experience as long as the tig welds are all done with the same stainless rod...there's no worry of anything breaking.I have a question about the "Mandrel Bent" exhaust which is where this system is supposed to end up.
Correct!if you look closely at the kit pics, you'll see that the sections of pipe that are tig'd together are cut sections of mandrel bent pipe and not crush-style bends that would restrict flow. They are some seriously free flowing pipes...and in my experience as long as the tig welds are all done with the same stainless rod...there's no worry of anything breaking.
Personally I would prefer one contiguous piece of SS pipe to one welded up from 4-5 separate pieces or so.
This would be extremely difficult to do, if not impossible.
Then I must have misunderstood what this means??
Something like this Ithought:
You did misunderstood what that meant. They stated and you quote:
We all realize what you meant the first time but you misunderstood what was stated.
Quote:
Originally Posted by AimCOtaco
One quick difference I note is that the heavy flanges make the system long term serviceable. Most of what I have seen from exhaust shops have re-used rusty flanges and weld new tubing to them. Also, not all muffler shops use mandrel bent tubing and add some restriction as a result of kinked bends.
The EMS system looks well designed and I certainly appreciate the quality flanges and clamps, I would prefer fewer welds between sections however. It appers the EMS may be built from many off the shelf pre-bent parts (thats how I have home built in the past anyway).
One thing I have not seen presented is tubing wall thickness of the EMS and DT systems which could also impact long term durability especially for off road use.
On the other hand I had a local shop chop in a magnaflow to the oem piping and delete the resonator for <$200 so I'm pretty happy for awhile. The EMS looks like it would flow and last much better than what I have now however. I have not looked too hard at the DT system yet. /end ramble
Quote BaktashT:
