i keep seeing this formula repeated across various threads and such...i think really all we need is the PID number itself, below are a bunch of snips from around the net that seem to be working for earlier generations of various Toyota's.
In Torque enter:
OBD2 Mode and PID:
21d9
Long Name:
Transmission Fluid Temperature 1 (or what you like)
Short Name:
Trans 1
Minimum Value:
0.0
Maximum value:
300.0
Scale factor:
x1
Unit Type:
°F (or alternatively C is you use the second equation below)
Equation:
((((E*256)+F) * (7/100) – 400)/10) – for output in F
____________________________________________________
OBD2 Mode & PID: 21D9
Long Name: Transmission Temp
Short Name: Trans T
Minimum Value: 0
Maximum Value: 300
Scale Factor: x1
Unit Type: *F
Equation: ((((E*256)+F)*(7/100)-400)/10)
OBD Header: left blank
__________________________________________________________
Name: Transmission Temp (pan)
Short name: Trans temp (pan)
PID: 2182
Equation: ((((A*256)+B)*(7/100)-400)/10)
Min Value: -40
Max Value: 325 F
Header: Leave emtpy
Name: Transmission Temp (Converter)
Short name: Converter Temp
PID: 2182
Equation: ((((C*256)+D)*(7/100)-400)/10)
Min Value -40
Max Value: 325 F
Header: Leave empty
Tredwards '05 LC
Scangauge:
TXD: 686AF121B4
RXF: 046105B40000
RXD: 2808
MTH: 00090005FFD8
Torque (maybe 2 sensors):
Sensor 1
OBD2 mode: 21B4
Name: Transmission Temp 1
Short name: TFT 1
Min value: 0
Max value: 300
scale factor: x1
Equation: A*(9/5)-38
OBD Headed: leave blank
Sensor 2
OBD2 mode: 21B4
Name: Transmission Temp 2
Short name: TFT 2
Min value: 0
Max value: 300
scale factor: x1
Equation: B*(9/5)-38
here's a few other links that may or may not be of help to us.
trans temp and AFR PIDs for a 99 4runner.
How To: Monitor Trans Fluid Temp (and other things) On Your iPhone - Toyota 4Runner Forum - Largest 4Runner Forum
trans temp for 1st gen sequoia's
Transmission Temperatures using Torque App and OBDII Bluetooth Adapter - Toyota Tundra Forums : Tundra Solutions Forum
*very* interesting information...
Guide: Converting ScanGauge Codes to Torque Pro PIDs - Toyota Tundra Forums : Tundra Solutions Forum
relative link to above.
» X-Gauge Categories » TOYOTA – LEXUS – SCION
____________________________________________________________
1 user reports.
None of these worked:
21d9
0105
2182
Gave 0 result:
01b4
Do you any in mind you'd like me to try?
i'm flying out for vacation tomorrow so im not going to get a chance to play with these for a few weeks, i'll do another data dump and report back if any of these work after i get a chance to play with it when i get back...
just to confuse issues more, it looks like they changed the transmission in the lx's in 2002 so there's going to be a split in the PID numers...
Lexus LX470 1998-2002 V8 4.7L 4 SP AWD A343F
Lexus LX470 2003-2007 V8 4.7L 5 SP AWD A750F
i would expect 98-02 and 03-07 to be different since it's a different trans altogether.
i found some specs for the temp sensor in the A343f trans, but it still doesn't help with the PID code.
{Toyota Repair & Electrical Manuals. The schematic says I should look for a Brown-White and Blue-White wires connected to the "A/T Oil Temp Sensor". It's a resistor that gives off 12.1 kOhms when 20 C (68 F) cold, to 780 Ohms when 110 C (230 F) hot.} quote
i'm going to keep digging and see what i can come up with in the mean time.
(off topic but really interesting for later model vehicles 06+ )
Hacking into a Vehicle CAN bus (Toyothack and SocketCAN)
ETA: i'll keep updating this post with the various PIDs that i find for the LC100 and LX470....i do think there will be a difference though in years as if im not mistaken the transmission changed mid-generation, so im thinking the PIDs changed as well.
