Middle seat "plumbing" - where to relocate?
DSRTRDR
I can mangle anything ...
Baton Rouge, LA and Fountain Hills, AZ
Hi,
my '72FJ40 has an "evaporative emissions control device" in the middle seat back of the front seat bench. This is the "plumbing" that accepts a gas vapor line from the tank and then feeds condensed vapor back to the fuel tank. I am wondering where to relocate this to when I get bucket seats - any ideas, experience, pictures? Thanks for any suggestions, Claudia :confused:
Claudia, I do not recommend trying to keep this system intact unless you absolutely have to for the smog nazis. Better to just cap it all off.
The 73 LCs had a better system with a full-on charcoal canister under the hood in the engine bay, where it belongs. If you really wanted a good system, you would use one of these and plumb it it.
The principle is simple: condense the vapors in the canister, send the condensed fuel back to the tank, and the vapors into the air cleaner to be drawn into the carb. The 72 tried to condense the vapors, but really had a difficult time getting the vapors to the engine. They were very prone to leaking, which was dangerous for the occupants of the vehicle.
I have never had a customer fail an emissions inspection for switching to the newer charcoal canister system. :)
i have a 72 and its not really needed to run correctly, i would just get rid of it by plumbing the two lines running to the emission can togther but if you really want a emission control unit follow 65swb45 advice and run a charcoal canister
thanks for the bellhousing and the t case shifter mark along with everyyhing else, we almost finished rogers 4 speed swap cant wait to see that tranny in action
thanks again, Freddie
Thanks Mark; do you have a suggestions where I should get the newer set-up from? Also, I anticipate I'll soon be sending my carb to you for a rebuild. Best regards, Claudia
Kind of a hijack, but I have a 1971 FJ55 with the evaporators in the rear cargo area, if I am doing a fuel injected engine swap can I completely do away with the evap. canisters?
Thanks,
Ryan.
Resurfacing an old thread.
I have a '71 FJ40 and took out the seats to put in buckets and found the charcoal canister inside of the passenger seat. I live in an area that does not have emmissions controls so don't have to worry about the "smog nazis". I have read some other threads that if I cap it off then I may get some fuel fumes in the cab. (Capping would be a whole lot easier than re-plumbing it.)
Have any of you who have capped experienced this?
If I plumb it into the engine bay, then what part do I need to buy and can someone shoot a pic of where I would mount it?
I have this same question and can't seem to find a good answer. I want to install bucket seats in my 71 fj40. What do I with the charcoal canister inside of the passenger seat. I'm not worried out emmissions, it's not an issue where i live. Do I just block the Lines? Will this create pressue in the system? Will I get gas fumes in the cab? I do still have the other charcoal canister in the right rear fender, it is connected properly. Do I need the one in the seat?
Capped mine off and use a vented gas cap. No fumes in the cab. Works like a charm.
