Spare on which side of the rear bumper?
TN
In your opinions which side should the spare tire be mounted on a rear bumper and why do you think its better on that side?
Thanks for the input.
ERG80
Driver side obstructs less of your view in the rear view mirror.
Mark...
Mine is on the drivers side, for visability reasons
I think he is going to mount it on the bumper, Not the side of the vehicle.
I understood the question. My answer is the side where the sidewalk is, depending on the country. The tire swings out and occupies space that can reduce the available road to passing traffic. It's a hazard on the traffic side.
Kalawang
Thanks for the input everyone.
I put mine on the driverside for visibility. More of a design thing but I wanted my fuel cans on the passenger side. This way I can syphon the fuel from the cans into the main tank and never have to lift the cans out of the rack. I kinda lazy that way.
D'Animal, My fuel door is on the drivers side. Wouldnt it be easier to syphon out of the fuel cans if they were on the drivers side also?
Erg80
Erg80
I wouldn't siphon cans unless they were on the ground. Static build-up.
Kalawang
Now I understand your answer. LOL
It makes sense that if you had to get in the back of your rig and you had to swing it out, you do not want it on the traffic side. I read that completely wrong the first time. :cheers:
Or, put a stop at about 93 degrees. This allows you to still get into the back of the truck and the tire occupies very minimal space in the traffic pattern.
Mine is on the passenger side. I had a slight lean (lower on the driver side) The weight of the spare on the passenger leveled things out perfectly. I don't have any complaints about visibility with it on the passenger side.
I prefer DS- easier to see out the back window. When you are backing up, you can lean your head out of the DS window to see what is there, but you've gotta look through the back window to see the rest of the world.
Kalawang makes a good point about traffic, but in reality your swing out shouldn't swing out that far anyway.
I like the tire on the drivers side.
-visibility
-easy to access rear from curbside parking. You don't have to go around the spare to access. If there is a car parked behind you, it would make it impossible from a PS tire.
(My swingout goes parallel to the bodyside, 90*. It doesn't go out into traffic 180*)
-I think PS is good for weight dist. since the gas tank is on the DS
Sidewalk side, depending on which country you're in. The traffic side reduces the available road for others.
Kalawang
They should swing open 90 deg so nothing really sticks out into traffic. Plus if you had it on the sidewalk side then you would have to walk around it while loading and unloading for the trip. But that's only a concern if you don't have a driveway.
I like passenger side dosent open into traffic and I always have so much stuff in back I can never see out the rear anyways!:doh:
I don't like the passenger side swingout on our old Pathfinder. It gets in the way when parked at the sidewalk. I'd put it on the driver's side.
