Suspension completed- tire opinions needed
Redding, CA
Just completed installing OME/Dakar 2.5 lift suspension and now need to buy some tires. Need some opinions on what size and brand to go with. I only do some light wheeling on weekends and is occasional daily driver. All is stock except for the suspension, new running boards will be installed soon just need to find a painter. I do not have power steering, nor guns like football lineman. Here's a pic of what she looks like with 235/75-15 tires. Let me know what you all think and any pics would be all the better. Thanks
BFG AT/TA 31x10.5x15 will fit on your stock rims no problem, it's what I'm running on both my rigs. Great on road and on the trail for light to medium wheeling.
Aren't your rear shackle inverted? Picture not clear enough
I'd go 33x10.5, BFgoodrich Mud terrain or All terrain, depending if its a daily driver.
I would go with BFG 33 x 10.50's (or 9.50's for that tall & skinny look)
AT's are a bit less noisy the MT's
Anything less will look small
I was thinking a 33x10.5 will rub in the back when flexing and might be a bit much if using the stock steel wheels(?). I have 4 inches of lift on my 40 and the 31's look fine, they'll look even better with a 2.5 inch lift.
Shackle angle
I think they will relax a bit they have about 5 miles and no wheeling on them at this point. Have a look.
Sounds like quite a few for 10.5's ...are they ok on stock rims and without PS? I definitely like the look of a bit wider as long as ther will not be any issues.
33x1050 all terrains are the best bet. Just make sure you dont put something too small with the lift or you will be mad you did. 33's slide in nicely and Bf goodrich is aggressive off road and good on the road.
i had 12.50's and switch to 1050's and they are much easier without the PS which i dont have either
Here's a shot in the summer with 32x11.50x15 and in the winter with LT255x85x16. Stock springs with 2" longer shackles and manual steering. I think it's pretty easy to steer and can't really feel the difference in power from the hight difference (the winter tires are just over 33" tall). I got really twisty going around a tank trap and managed to hit on both sides with the summer tires. I dropped my bump stops down 1 1/2" and haven't hit since (probably not optimum articulation but I've never noticed it bottoming out). Just my 2 cents.
Yep there installed ok, i had the OME shackle in mind. Mine (the OME) are like those on this picture.
The side facing the axle didn't have that extra pin, so i thought they were installed not facing the axle
attachment.php
