No need to call
The wheelbase multiplyer is the OLD law... thank heavens the U4WDA helped push a new law through the legal system (reason enough to join the U4:
http://www.u4wda.org/
As for the NEW law (its actually pretty old
41-6a-1631. Prohibitions.
(1) A person may not operate on a highway a motor vehicle that is mechanically altered or changed:
(a) in any way that may under normal operation:
(i) cause the motor vehicle body or chassis to come in contact with the roadway;
(ii) expose the fuel tank to damage from collision; or
(iii) cause the wheels to come in contact with the body;
(b) in any manner that may impair the safe operation of the vehicle;
(c) so that any part of the vehicle other than tires, rims, and mudguards are less than three inches above the ground;
(d) to a frame height of more than 24 inches for a motor vehicle with a gross vehicle weight rating of less than 4,500 pounds;
(e) to a frame height of more than 26 inches for a motor vehicle with a gross vehicle weight rating of at least 4,500 pounds and less than 7,500 pounds;
(f) to a frame height of more than 28 inches for a motor vehicle with a gross vehicle weight rating of at least 7,500 pounds;
(g) by stacking or attaching vehicle frames (one from on top of or beneath another frame); or
(h) so that the lowest portion of the body floor is raised more than three inches above the top of the frame.
(2) If the wheel track is increased beyond the O.E.M. specification, the top 50% of the tires shall be covered by the original fenders, by rubber, or other flexible fender extenders under any loading condition.
