I posted a thread about my installation a couple years back (see here), and since then have had several people ask if I would produce a kit. After considerable time and effort, here it is. This is a fully bolt-on charge air cooling solution that uses existing factory-threaded holes to mount the front heat exchanger and requires no hood modifications to accommodate the IC core (some slight trimming of the underhood insulation is recommended). Routing of the coolant lines can be accomplished without any sheet-metal cutting, but a couple of strategically-placed holes directly behind the passenger-side turn signal make for a nicely-hidden installation.
At this time I’ll be offering the kit in two different configurations. The Basic Kit includes the main fabricated parts, leaving the circulation pump, wiring and plumbing up to you. The Master Kit includes everything needed to get up and running. Both kits will also come with detailed instruction notes and photo documentation. It’s not exactly a step-by-step manual, as there are too many variations in how different trucks are set up, but gives enough detail for the slightly-above-average shade tree mechanic to complete the install.
Basic Kit ($1250):
Intercooler Core
Intake Flange
Coolant Pump Mounting Plate
Heat Exchanger Mounting Brackets
EGR Modulator Relocation Bracket
Master Kit ($2250) includes all of the above plus:
Coolant Pump (Meziere all aluminum 20 gpm)
Coolant Pump Fittings (x2) (AN to 3/4" Hose Barb)
SS T-Bolt Clamps 3" (x4)
Silicone Straight Coupler (x2)
Heat Exchanger
Heat Exchanger Fan (7")
Remote Fill/Bleed Cap 3/4"
Silicone Heater Hose 3/4" (20')
Silicone Hose 6mm (6' for overflow)
Brass Elbow 3/4" (x6)
Brass 1/2" NPT Male to 3/4" Hose Barb - Straight (x6)
Brass 1/2" NPT Male to 3/4" Hose Barb - Elbow (x4)
Rear Heater Switch (OEM Toyota)
Wiring and Fuse/Relay Kit (x2 for Coolant Pump and IC Fan)
Wire Loom, Fuse Tap, OEM Terminals for Connection to AC Pressure Switch, etc.
I realize this is not cheap, but I believe it to be a robust system that should last the life of the engine with routine maintenance (coolant flush every few years, just like you would do for the engine’s cooling system), while providing an extra margin of safety from detonation. I make no guarantees regarding performance or anything else for that matter, but have been very pleased with the performance of my truck for the past 20k miles with the combination of the intercooler and 2.8” supercharger pulley providing smooth, reliable power.
Keep in mind that this is not a quick installation. There are many systems involved, and one should budget at least a couple of days. Feel free to contact me with any questions or for more detailed information - dfeher@me.com or PM through ih8mud works as well.
- Basic Kit -
- Master Kit -
- Overview showing IC core and intake flange connection -
- Heat exchanger mounted behind stock grille (minor trimming required) -
Basic Kit ($1250):
Intercooler Core
Intake Flange
Heat Exchanger
- Basic Kit -
- Master Kit -
