Ok so I simply have a bad vibration starting at 50mph, worst at 55mph, and goes away at 60mph.
Just took it to the shop to have the rear drums adjusted and wheels balanced and trued but was told my vibration is caused from a recent axle repair I made. They haven't told me anything else other than that. Going to pick it up tonight.
Back story, I removed the driver side rear axle after another shop told me a axle seal was bad after they discovered fluid in the brake drum. Come to find out nothing was wrong with the seal and that the wheel cylinder was causing the fluid in the drum. Put the axle back together with fresh oil and replaced the wheel cylinder. I failed to adjust the wheel cylinder out properly which ended up causing some braking issues that resulted in new front calibers being replaced multiple brake bleeding, the recent shop just adjusted the rear drums for me. But during the brake issue it resulted in sticky front calibers causing overheating. The overheating also caused the driver side weights on the wheel to not completely come off but become loose.
So my questions are could anything listed above cause the vibration, and if it could be coming from the axle itself what could I have missed when assembling it that could cause a vibration at high speeds, if anything.
Thanks for any help you can provide. When I get the cruiser back tonight I'm going to double check the Phase of the drive shaft and possibly rotate the tires to see if it changes.
Oh lastly, the shop said the center arm, or bell crank is bad causing eratic steering conditions, should I try to adjust before rebuild, and if so how do I adjust the center arm. thanks.
