Builds The new FJ 73 Build (1 Viewer)
Wild thing!! You really have them springs dialed in now!!
I have come to the conclusion that a possible name has arisen from the internet, you shall have to rename the
thread - "Wild Thing"! I don't think I've seen a 70 series more fitting of the name. J
A bit has happened in just under a year.
Got the ram mounted and some what figured.
Had to move the tie rod to the top of the steering arms, and move the drag bar to the top of the pitman arm.
After many revisions I got it just right.
Had to extend out the hard stops as the ram was just short.
Axle side mount.
I added another plate to box off the section once I had I welded to the axle and a tube gusset to the reinforced section
Nice and parallel to the tie rod.
tacked up.
Ram ends shortened redrilled and profiled, would have been much easier with a spherical bearing end ram but what's the fun in that.
Tie rod and drag bar stacked on top and the steering arm. Now the ram will be doing half the work I'm happy with them both being on the top side.
Tie rod end mount.
boxed and gusseted, drain hole cut in the front section.
Wow, pretty heavy duty! I'm curious as to tie rod tube, is it factory? If I remember, 60 guys use 80 series
TRE's and tube because the tube is somewhat thicker. I guess what I'm asking is with all the heavy duty brackets,
will the tube withstand the forces? I agree, spherical rod ends would certainly have made your job a lot easier.
The new FJ 73 Build
Back on page 5 theres the build on the tie rods and drag bar. Its 1045 bright bar solid 30mm with 5/8 and 3/4 spherical ends.
There pretty robust. Lol.
sort of missed that part I guess. J
All good, that was one of the things I wanted to sort fairly early in the piece.
Didnt like how the drag bar mounted to the tie rod just didnt make sense to me, evrytime you turn the wheel it layed the tie rod end over.
Checked all the clearances at full flex today, had to scallop one plate a little bit but besides that all good,
Just waiting on a 1/4 bsp tap and some nipples and we are good to go.
little knotch for clearance.
Axle side mount.
Clearance of drag link at full up off frame is perfect.And mount is well clear of motor and so on.
looks a little close, but is a godd 15mm
Saw these for sale a few weeks ago and couldn't let them go.
37 x 14.5 Creepy Crawlers and comp spec et -100 15"steel wheels.
These are custom built stoutest wheels i have seem easily, the beadlock rim is 4mm steel and the spokes mounting face is 10mm plate.
They have been run on a few comp trucks at Willowglen and others.
They had a few leaks and broken bolts so i stripped them down, and gave them a lick of paint.
4mm Beadlock rims.
Had to shave the front calipers and smooth the rear of the wheels and they just fit, no more spacers for me.
Just where the material had stretched from pressing out the holes.
Fatso
Deeeeeeeeeeeeeeeeeep Dish.
New hardware flat black.
Back to the hydro assist, stripped the steering box.
Drilliing to tap 1/4 bsp.this top hole is aiming for a small vein and position is fairly critical, milling machine makes easy work of it.
Internals stripped.
You can see the vein running down the centre of the lower tapped hole, bang on.
Second hole on the side not so critical, power tapping the hole, again 1/4 BSP
Ready to go back together.
A spot of Yoga was needed to sus out the clearances on the front end,
Went to town witht he grinder loosing a heap of sheet metal and trimming the flares down a heap too.
Fender lip trimmed about 30mm up, inner well trimmed.
Flares trimmed.
Ended up something like this, added a little section to deflect crap from the battery.
Somewhat normal from the top view.
On the bump stop tucking 37's
Pretty impressive now with the fat rubber, very sturdy and feels a lot higher than earlier.
Because the front axle is forward about 75mm the bump stop wasnt hitting the old target very well.
Added a bigger reinforced platfrom, am looking at some hydro stops in the future.
Finished up the bump stop plates. And added some knuckle ball gussets.
Looking and feeling like a built axle now.
