The Diesel Part number thread. NO CHIT CHAT or PARTS # REQUESTS! (2 Viewers)
1-HDT 4.2 L 1991 JDM
SHIM, VALVE ADJUSTING Part number
each shim cost around $4.66
Shims removal tool part number: SST 09248-64011 (For Adjusting Value Clearances)
13753-17040 T=2.40
13753-17090 T=2.35
13753-17100 T=2.45
13753-54010 T=2.50, T01
13753-54060 T=2.60, T06
13753-54110 T=2.70, T11
13753-54160 T=2.80, T16
13753-54210 T=2.90, T21
13753-54260 T=3.00, T26
13753-54310 T=3.10, T31
13753-54420 T=2.55, T42
13753-54430 T=2.65, T43
13753-54440 T=2.75, T44
13753-54450 T=2.85, T45
13753-54460 T=2.95, T46
13753-54470 T=3.05, T47
13753-54480 T=3.15, T48
I did a like coz I like the info ( thanks Onur ) .. but should be a unlike button too .. damn Mr. T ... not supporting loyal customers ! ( yeah I know Mr. T is more interested in those who buy new 200 series each year )
1991 HDJ80 hdt-1 Rear Axle seal and bearning replacement. "Semi-floater"
FJ 80 vs. HDJ-80
Bearing 90365-47013 vs. 90368-49013: same part with two different parts numbrer
Seal 90311-47001 vs. 90310-35001: same part with two different parts numbrer
Anyone got the part number for a 1KZ exhuast manifold?
From a JDM surf.
I just went to the Toyota Whiterock BC dealer to order
a valve cover gasket for 84bj60 3b.
valve cover gasket - 64.00 inc tax
fuel filter- 59.00
I need to find a supplier to price these parts out at better prices.
Beno can you get parts for Hj60's
Oil return and high pressure lines and gaskets. JDM 3B application but they should be applicable to most 3B/13B-T engines.
Gaskets available in US market. Hoses came from Japan:
Windshield frame for a soft top BJ70. All softtops share this number (ie: they all supersede to this number):
Factory soft top:
2H engine gasket kit (OEM, available in North America).
Standard thrust washers:
Standard ring set:
Camshaft bearing set:
All available in the North American parts system with TMS.
Back in the day I remember early 2H had no cylinder sleeves while late does have, so head gaskets change accordingly I'm missing something ?
Correct. Early is discontinued from Toyota. Only the late remains. You can get the early head gasket separately and use the engine gasket kit from the later iteration.
