The Diesel Part number thread. NO CHIT CHAT or PARTS # REQUESTS! (2 Viewers)
16400-17020
OEM TRAD Radiator for HZJ/HDJ8x trucks. It does not have the automatic transmission cooler bits installed underneath.
Nice unit. Available in the US market.
B/2B engine gasket kit is still available from Toyota. Amazingly enough. Very nice kit with MLS head gasket.
Some of these parts would also be applicable to a 3B or a 13B-T. Some.
2b alternator and water pump fan belt. Pulled off a Gates B45 replaced with NAPA B45. Go figure.
Looking for a replacement hose for 87245-90A24. Its for the rear heater water inlet hose. HJ60. 2H
Any US parts? Found replacement in AU but shipping is twice the cost of the part.. Anyone have a US part number for MACKAY they make the part in Australia. Thanks.
Do it yourself a with silicone or rubber hose. Don't bother with a OEM part that could be at an exorbitant price !!;)
Hey @beno, what's the difference between a 83530-30060 and 83520-60011? Toyodiy isn't very clear on the descriptions.
Just picked up two new Gates brand alternator / fan belts for the HZJ73.
1HZ / 1HD-T GENERATOR BELT
GATES PART# 70395
Edit: Gates PN 7395 (incorrectly noted above as 70395) is incorrect for the 1HZ. I removed the worn out 15406 and wasn't able to find at Autozone or Advance Auto but 15405 was available and it fit fine. However 15406 WAS available at Napa, for 2x the cost. I believe the length is denoted by the numbers and the difference is either 40.5" vs 40.6" or 5405mm vs 5406mm.
2H + 12HT Water pump
Aisin WPT-051 ( WPT051 )
Fit OEM
16120-68010
16120-69015
16100-89037
HJ61
HJ60
DYNA / COASTER HB30 ....
Lucky me ! Second pump in 2 weeks ! :(
3B + 13BT
Aisin WPT-074 ( WPT074 )
Fit OEM
16100-59105
BJ42
BJ70
Bj71
BJ73
BJ74
DYNA / COASTER BB20 ... ....
3B, 13B-T Fuel Lift Pump
Denso part numbers
192290-0060 Overhaul Gasket Kit for type KE & KS pumps
152116-0200 Check Valve, Spring
949150-2700 Push Rod, Seal ( Parts & repair Manuals don't show this seal ) see below
Trying to baseline a 1HZ, if I have any PNs incorrect or missing any items, please let me know so I can add.
1HZ Timing Belt, water pump, radiator hoses, thermostat
16100-19235
Water Pump Assembly
16271-17010
Water Pump Gasket
13568-19065
Timing Belt
11321-17010
Timing Belt Cover #1
11328-17010
Timing Gear / Chain cover gasket
13505-17011
Idler sub/assembly, timing belt #1
90507-27001
Tension Idler Spring
90468-05034
Timing Belt cover clip (4)
11213-17010
Cylinder Head cover gasket
90311-58006
Oil Seal (Timing chain/Belt Cover)
90311-58007
90916-03089
Thermostat
16346-66020
Thermostat gasket
16572-17020
Radiator Outlet Hose
16571-17020
Radiator Inlet Hose
90341-12012
Drain Plug
90430-12031
Drain Plug Gasket
