T-Max / IBS Dual Battery System Install Guide
It took me a long time to wrap my head around everything needed to install a dual battery system. I tried to compile a step by step how to guide to make it easier for others. Thanks to SanDiegoCruiser for the help and DomSmith for the crimper and cable making lesson.
TOOLS:
SUPPLIES:
The project could be a lot cheaper if you chose a thinner gauge cable because smaller gauge terminals, heat shrink and crimping cutting tools are cheaper too.
You don't necessarily need to use the in-line 200 Amp fuses. The instructions don't call for them. But the national luna kit does include them. The idea is that if the solenoid craps out, or if there is a short in one of the positive cables, the fuse will blow, preventing a fire. The 200amp fuse is sturdy enough to allow for self jumping. The fuses should be placed as close to the batteries as possible.
For the green cable, you can use the in-line fuse holder that comes with the T-max kit, but I chose to use a heavy duty weather proof one instead.
The T-Max kit comes with most of the cable you'd need but it's only 6 gauge black cable. I chose to go with 1/0 gauge to allow the headroom for a future inverter and winch.
TOOLS:
- Hammer Crimper
Amazon.com: Ancor 701010 Marine Grade Electrical Heavy Duty Lug Crimper (6 to 4/0-Gauge): Sports & Outdoors - Big Hammer
- 1/0 AWG or better wire cutters
- Utility knife and fresh blade
- Ratchet and various sockets
- Heat gun
Amazon.com: Wagner Power Products 503008 HT 1000 1,200-Watt Heat Gun: Home Improvement
- Tiny flathead screwdriver
- Philips head screwdriver
- Scissors
- 8-22 AWG Wire cutter/stripper/crimper
SUPPLIES:
- Slee 2nd Battery Tray
Slee - Battery Related Products
- T-MAX 47-3800 Dual Battery System
Amazon.com: T-MAX 47-3800 Dual Battery System: Automotive
- Optima 8012-021-FFP YellowTop Group 34 Deep Cycle Battery
Amazon.com: Optima 8012-021-FFP YellowTop Group 34 Deep Cycle Battery: Automotive
- 1/0 Gauge 25ft Battery Cable Red (Only used half)
Amazon.com: Raptor BC1/0R-25 1/0 Gauge 25-Feet Battery Cable (Red): Car Electronics
- 1/0 Gauge 25ft Battery Cable (Only used half)
Amazon.com: Raptor BC1/0B-25 1/0 Gauge 25-Feet Battery Cable (Black): Car Electronics
- Techflex 3/4 F6 Split Sleeving 25 feet Black
- Anchor Marine Grade Adhesive Line Heat Shrink Tubing Various Sizes
Ancor 301506 Marine Grade Electrical Adhesive Lined Heat Shrink Tubing Kit (3/16 to 3/4-Inch Diameter, 6-Inches Long, Black, 8-Pack): Amazon.com: Sports & Outdoors
- 14x Anchor Marine Grade 1/0-Gauge 5/16" Screw Tinned Copper Lugs
Amazon.com: Ancor Marine Grade Electrical Heavy Duty Tinned Copper Lugs: Sports & Outdoors
- Ancor Marine Grade Adhesive Lined Heat Shrink Tubing 3/4in by 48in
Ancor Marine Grade Electrical Adhesive Lined Heat Shrink Tubing: Amazon.com: Sports & Outdoors - 2 x Single ANL Inline Fuse Holder
Amazon.com: Scosche EWFH Single ANL Fuse Holder: Car Electronics
- 2 x 200 Amp ANL Fuse
Amazon.com: Raptor RANL2002 200 Amp ANL Fuses, 24K Gold Plated, 2 Pack: Car Electronics
- Heavy Duty 30 amp In-Line Fuse Holder
Cooper Bussmann/30 Amps maximum heavy-duty in-line ATC fuse holder with cover (BP-HHG-RP) | Fuse and Accessories | AutoZone.com
