- Thread starter
- #41
here's one great thing about toyota. with all the new components that came with the 3fe, they still use the same bracket mounts and threads as they did before with the 2f, like the 2f alternator bracket mounting up to the 3fe head. again i'm installing all things emissions, and thought i'd put this up because i didn't see much good info covering this. which is also why i'm asking for the 3fe charcoal canister routing
1) the filter(?) for the air injection system, using the same holes as the 2f air intake hose bracket and some other hole. note that the 3rd mounting hole that's underneath isn't bolted because there is no hole in the 60's wheel well for it.
2) the switching valve for the 3fe ai system bolts right up to 2f abv valve bracket. this is taken standing up against the driver's fender looking down on the wheel well
3) the later charcoal canister is a direct bolt in to the earlier location.
