An alarming title but…this is with the plug out! So, I had hooked up a bypass tube between my tranny and transfer the other day and had both fill plugs out to do it. A slight trickle was coming out of the transfer. It didn't seem to stop after 5 minutes (tiny thread of a trickle) but I assumed it was just dripping down from the gears or something and that there was pretty much the correct amount of oil in there. And dipping my finger in the tranny fill hole I could touch the oil. So all seemed good. I installed my bypass hose…and since then, I noticed a small leak from the connection of my hose onto the transfer case. So I took the banjo bolt out of the transfer plug hole to tighten the hose connection and suddenly a lot of oil started flowing out and hadn't stopped even after a minute or two (probably lost about half a cup). I put the plug back in to stem the flow and came on here to say…what the heck is going on? How is it the oil levels were fine when I had the two plugs out previously…and now suddenly oil is appearing from…somewhere? I have not yet checked the transmission oil level as I wanted to ask advice here first. Any takers?
