murf
Lifer
Phil, you mentioned that you chose those tires due to thier light weight for the lowest unsprung weight. what kind of tire pressure did you end up running with?
This could be just the ticket to getting the better half out camping. What is the time needed to recharge the battery say after an evening where the blanket was on three times?
Would a larger solar panel deliver a faster charge time?
Nice set up for cold nights, so what is the difference between the 12volt heated blankets and the 110 volts blankets if you have an inverter and battery!
Testing continues....
I continue to push where I take the trailer and its back there every time I look. I say when I look because I cant see it with no rear view mirror and not viewable from the side mirror The high tongue is proving itself priceless, without I dont how it would of make the pictured obstacle. The new low lowrange gears make going slow much easier and I dont even feel the trailer much anymore.
The bed is now heated and I have more then enough power from the mini power supply to provide the needed heat. I ended up heating the mattress because It was too hard to control the temp used as a blanky. With the mattress heated its great going to bed in a warm bed and turning on early in the AM befroe getting up. The heat is variable so I have control to kick it up a notch when the princess is present. Winter camping is now very comfortable.
WOW Phil looks great. Color me green with envy
Phil, do you have any pictures from the step you build under the entrance to your tent, I like the idea for when is raining!
Looking good Phil. All the research paid off
You mention the new low range gears, I must of missed that thread. What did you end up going with?
I used to have a Blue Heeler named him Blue Suede.
