I pulled my fuel injectors in my '97 LX with 253k miles and brought them to a local injector shop for cleaning/servicing. I've used them many times before for diesel injector cleaning/servicing.
While the upper plenum was off I decide to clean the oily crap out of it, and wiped out the lower plenum.
Also changed to new OEM plugs while everything was apart, wires are fairly new. Everything was running perfectly fine before pulling the injectors.
After reinstalling as per the FSM, the LX was really hard to start. I kind of expected this due to the fuel rail being empty. Ok, no prob. Once it started up it had a bad shake to it and tons of smoke. P0305 misfire in #5.
Damn, should've inspected the wire harness at the EGR better like everyone suggests. I proceeded to pull the EGR valve, and inspect all wires at the location, all good. Sealed it up with some heat wrap. I then checked the main harness behind the glove box, all good. Checked the continuity and 12V at the ECM, all good.
On to the spark and compression test. Spark is good at cylinder 5. While doing the compression test there was excess fuel spraying out of the spark plug hole. I had run it a bit, so I think that's just from no ignition what so ever. But it's getting fuel.
Compression test 145-150 on all cylinders but #5, 110. This was done cold, with the harbor freight tester and mediocre battery charge.
Not sure how or why, but could that injector be failing and just constant fuel coming out?
I've never used this shop for gas injectors, they specialize in diesel injectors and turbos.
Next step, I'm going to pull the lower intake plenum off to take a better look. Maybe there's a tiny bit of crud that I dropped in there that is keeping the intake valve from seating?
Swap the injector to a different cylinder, button everything up and see if it moves?
