Guys, my 1975fj40 with 4 inch old man emu lift and extended shackles is on 33 inch AT's. Been shaking violently on freeway above 40. Just had tires rotated and balanced and front end alignment with no change. Took in to a friends shop and he turned it over to his master tech..
Just got this text
My tech is saying its either an axle issue or something inside the differential. Nothing suspension wise is worn except the leaf spring bushings on the front part of the leaf spring. The left side bushing is starting to come apart and the right side is very minor. Both have no movement with a pry bar. We tested it while its up in the air and the whole rear axle shakes violently. So we removed the tires to see if maybe one was out of round and causing the shaking and that didn't make a difference.. The whole rear axle would do the same thing. Suspension is good, so is both drive shafts, and u-joints.. He did notice the rear axle is shifted to the right and the right wheel has a two finger gap between the wheel and fender and the left has about 3 finger gap. Tires are pretty much at a point where they need to be replaced based on the center tread depth but as much as you drive it you probably don't have to worry to much about them. They don't look super dry rotted just minor cracking... Unfortunately we don't do anything with differentials.. My only option would be to remove the whole thing and send it out to AZ rack and axle or AZ differential...
Not sure what to do...what do you guys recommend? Truck is almost nondriveable
Just got this text
