On my way to drop off the boy at daycare, my passenger mirror moved into the window. I am not talking about normally shaky mirror syndrome, but the mirror pivots on it base freely. Like when you pull them in for a tight garage parking job. I took apart the mirror after work and figured out what is wrong, but cant fix it and need help. I know the mirror uses a spring to put tension on the normal position so it doesnt shift in traffic. The spring rests on a post with a few discs on top (for movement) and a U-shaped disc to provide the tension constantly. How in the world do I compress that spring to place the U-shaped pin back again??
I have tried pipe clamps and all sorts of way to compress it, but can find a way to compress it enough to slide the U-shaped disc into lock the spring down. Any thoughts or fixes? I tried searching, but all I find is the shaky mirror syndrome, thats for another day.
