OK...how does one eliminate the feedback issue...i.e. trailer battery feeding back into LC...anyway to rig up a relay? and where to do it?...could the relay be on the trailer side? i have an 2003
Where did you guys attach your groud wire? I was ablt to locate the plug by doing some fancy body bending but what a mass of wires!
I installed my brake controller today according to the posted directions. My LC has the tow package and 7 pin connector to my trailer. Will this set up charge the trailer battery without any other mods?
Is there a brake controller connected to the pin? The connectors follow a standard numbering convention that doesn't mean all the pins are connected. What do you plan to tow? Lighter loads really won't need a brake controller.
Sent via the ether from my candy bar running ginger bread
You do need the controller...marking on the socket assumes you have a live circuit from the controller to the socket.I have been reading a bit about this topic. I am a bit confused so hopefully someone can help me sort things out.
I have this:
It is located behind my rear crossmember (bumper). If i were to tow a trailer with electric brakes, would i still need one of those teckonsha prodigy brake controllers even though i have a 7-pin plug that says one of the pins is for "electric brake"? This 7-pin plug came with the truck when i purchased it. 03 LX
I'll add a controller once I hit half a ton or so. State says that trailer brakes are required for trailers weighing one ton or more. Without electric brakes you'll see significant wear on the LC brakes.Is there a brake controller connected to the pin? The connectors follow a standard numbering convention that doesn't mean all the pins are connected. What do you plan to tow? Lighter loads really won't need a brake controller.
If you don't have a controller installed in the cab, get to the back of the connector and see if there's a wire attached to the connector brake terminal.I don't know if there is a brake controller connected to the pin. How would i be able to find out? I don't plan on towing anything large... yet. (boat perhaps in the future) Right now, i'm actually more concerned with trying to figure out how to charge a battery in my tongue box of my m416 utilizing the 7 pin connector that i have.
