I've tried a couple different methods for setting my wheel bearing preload (new Koyo's)and keep coming up around 13-14 lbs. This last time I tightened the inner nut to 45 ft lbs, backed off, then tightened the inner nut to 10 ft lbs, then installed the lock washer and outer nut, and torqued that to 45 ft lbs. Spun the rotor a few times each direction and checked the turning force needed to move the rotor in each direction using a digital fish scale a few times and I've been getting 14lbs. I've read here that some people like to set new bearings a bit higher than spec; is that OK or just start over?
