That's interesting. So even torqued to 20 foot pounds the rotational rolling resistance is only 2 foot/pounds?
How tight can the bearing be set up safely? The tightest safe set up would result in the least possible wear on the spindle, I think.
Tools R Us: I'm having a hard time understanding your experiment but understand your point that there is a lot of drag in the system that isn't due to the bearings. I once watched an experienced mechanic adjust wheel bearings, he just went entirely by feel; spun one tire then the other, when back and loosened up the inner nut, spun the tire again, done. I don't remember him using a torque wrench and for sure no scale of any sort.
We set the preload on thousands of wheel bearings just by feel in the shop I used to work in. You tighten up the nut to about 25 ft lbs and then loosen it until it is free and then tighten it to about 5 ft pounds and that is it. You can verify the tightness by moving the washer under the nut. If you can move it and there is no play in the bearing, it is OK. If you can't move the washer, it is too tight. All of these worked out fine. This means that setting the wheel bearing preload doesn't require an extreme accuracy. The whole procedure takes about 1 minute.
If it is too tight, the bearing will heat up and fail.
It is hard to go wrong with the methods in the FSM, even if it might be more involved.
Maybe I am the only one with this problem but I have set my bearings to the FSM and eveytime I torque the outside nut the inside nut turns then the lock washer shears. I believe I have mine set at 10 ft lbs inside and about 40-45 outside. Just curious if anyone else has experienced this problem?
anyone have been checked at which point the outer nut torque start afecting the inner nut .?
I usually tight the outer at least 60 lb/in .. or so ..
I dont like allot of the advice in this thread.
Too tight burns up bearings and the tire/wheel/rotor will pass you up.
Too loose and they will be, well too loose.
The guy tearing the titty off the washer.....
Go to the dealer for the next washer, the aftermarket ones are soft junk.
