Looks like it. Still doesn't explain your problem. The HG looks fine. I guess having the head checked has to be the next move.
How was the engine running?
When you did the oil change, you didn't by chance put in Pennzoil did you? I have known of a couple instances where Pennzoil turned to Jello in the crankcase. It's possible that if you caught it before it completely converted, you may have saved the engine as a whole.
BTW, if there is a crack in the head, I'll put my money on Cyl # 3 between the two valves based on the discoloration.
Dunno yet...
Another question for those in the know... Is there a way to get just the plastic wire connectors (female ends) for all the fuel injector wire connections and other misc. wire connectors? Every single retaining tab on every single connector broke off while removing them. This engine must have gotten HOT!
Most of the connectors should have a 5 digit number on them that is the second half of the part number. The first half is usually 90980.
I see no mention of those plugs in the repair manual under the cylinder head section. I would guess they are similay to freeze plugs and would just leave them be. The spec for head warpage is 0.0059 in. max. If it was an overhead cam head I would replace it, otherwise I would have the machine shop resurface it and reuse.
So how do you think you're cylinder head got so warped, perhaps overheating?
Just wanted to say thanks for logging your progress on this, it will surely help others.
