OK, any advice here? 40 over motor, decked heads, Downey Torquer cam, MAF tri-y cermain headers, demogged and no cat. Stock Asian carb.
Problem: big flat spot going off idle. Like it stumbles and wants to stall, unless I rev it up and feather in the clutch. Bucks and chugs when trying to cruise in 3rd, at less than 30 mph. Big, huge backfires when decel.
Above 45 in 4th, seems to run fine, nice and smooth. The decel backfire is VERY annoying, though
Is the stock Asian carb to small for this engine now? Even if I do re-jet, will it work, or should I go with a Weber or Holley conversion? I'd much like to stay with the Asian, if I could
What is causing the backfire? any ideas?
